Old 07-17-2016, 11:44 AM   #21
2007 WildCat 32QBBS
05CrewDually's Avatar
Looks great! Glad you found a solution. Another benefit is now your trailer is more universal and can be towed by any standard fullsize truck if you decide to trade in or ever need it towed by another truck.
05CrewDually is online now   Reply With Quote
Old 07-17-2016, 12:34 PM   #22
Before raising the unit, check the king pin assembly. Most built today can be lowered or raised several inches.
BBQGUY is offline   Reply With Quote
Old 07-17-2016, 01:25 PM   #23
2007 WildCat 32QBBS
You're way late to the party.
Old 07-17-2016, 01:33 PM   #24
Kenny kustom's Avatar
My sabre was nose high on my new ram.
I couldn't raise the trailer, as I only have inches to spare under a bridge that I frequently go under.
So I lowered the rear of the truck and lowered the hitch.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 07-18-2016, 04:50 PM   #25
PhoneDude 8289's Avatar
2016 Sabre 36QBOK
I looked at those options before raising the RV. My 2014 Ram 2500 has coil rear springs not leaf. Cutting the coils or installing coils from a 1500 not an option. The hitch in the truck is sitting on the bottom and the factory revolution on the RV has no adjustment. I raised the trailer 3" and all is good. On level concrete from ground level to the top of the front air conditioner 12' 10" just clears. 13' is what I call good to go.
Lifted 2014 8289WS Diamond pkg
2014 Ram 2500 4wd SB DC TCD
PhoneDude 8289 is offline   Reply With Quote
5th wheel, wheel
