Old 08-22-2016, 03:02 PM   #1
Need to solve a problem. Any ideas?
I am looing for a mod that can help solve a problem. I was recently camping with the family. I was cooking at the outdoor kitchen. When suddenly and unexpectedly it started to rain. I found out the hard way that when the outdoor kitchen is open and it is raining the rain can fall in between the outdoor kitchen roof and the side of the camper. I am trying to think of a mod that can help with this problem and still be functional when on the move and look good when the kitchen is closed. Has anyone come up with a way to solve this problem? Thank uou for all and any ideas.
R HEMI is offline   Reply With Quote
Old 08-22-2016, 03:06 PM   #2
Awning? Either one of the slide ons like used on tent trailers,,or a roll up like your main awning.
donniedu is offline   Reply With Quote
Old 08-22-2016, 03:06 PM   #3
heavynlori's Avatar
Maybe a section of that vinyl shower door flap that goes on the bottom of glass doors could be installed over the hinge along the top of the door for your outside kitchen.....
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is offline   Reply With Quote
Old 08-22-2016, 03:08 PM   #4
Is the 'roof' you are referring to simply the outside storage door to the kitchen in the raised position?
How about a patio awning on side of the camper where the kitchen is?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
Old 08-22-2016, 03:09 PM   #5
Wobbles's Avatar
Just a cheap idea... Cut a piece of flexible L shaped rubber to length. Should act like a gutter. When not in use throw it inside the outdoor kitchen.
Come back and post your solution...
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2015 Grey Wolf 26BH
Wobbles is offline   Reply With Quote
Old 08-22-2016, 03:09 PM   #6
JustB_Rad's Avatar
I would say a 1/2" wide piece of rubber the length of the door over the hinge would work. I would say either double sticky back tape of silicone would keep it in place.
Or a piece of weatherstrip
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
(2017)16 Night Booked in 4 Trips - 6 in 2 more Trips Planned
JustB_Rad is offline   Reply With Quote
Old 08-22-2016, 03:12 PM   #7
Flybob's Avatar
Had the same problem with my OD kitchen. My thought ( although haven't had time to try it) was to add a "C"-track to the side of the trailer just above the door opening. Then have a small awning made that could slide into the track and extend to the open end of the door where it could be attached with snaps or bungees. It could easily be removed when not needed and during travel. The track would blend in well with the top of the door frame.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-22-2016, 03:16 PM   #8
JustB_Rad's Avatar
I guess after thinking about it, is this water thats running down the side of the unit or water thats running back towards the unit from the door?
Old 08-22-2016, 03:27 PM   #9
You are thinking like me.
That's why I asked the question about what the 'roof' was exactly.
Old 08-22-2016, 03:30 PM   #10
Wobbles's Avatar
I think the OP is referring to the lift up kitchen door.
Bob & Michelle
2015 Grey Wolf 26BH
