Old 04-02-2012, 09:27 PM   #1
trudinator's Avatar
New Awning Mod
Here have been many posters who are concerned with hanging lights, etc. off of their awning because of the threat of bad weather and having to quickly pull their awning in. I've even seen some posters on here who want to remove their power awning and replace it with a manual awning (huh???) my DH has come up with a pretty nifty mod, which you can see in the photos. It's a 1/16 inch wire rope, attached at the ends of the awning arms with snap clips. One end has an expansion spring. Required drilling a hole through the awning arm, which was pretty easy. Hang your lights from the cable, and if/when a wind comes up, just unclip the cable at each end and roll up your awning. It is designed to be able to roll right up with your awning, which it does when we tested it. So you could leave the cable and light string on it in an emergency. The lights will just hit the door, which is better than losing your awning! We'll remove it for travel. Can't wait to try it out fully this coming weekend! Hope the attachments work from my iPad,,,first time attaching photos from it.
ID:	11654   Click image for larger version
ID:	11655   Click image for larger version
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 04-02-2012, 09:36 PM   #2
sherdep's Avatar
spring loaded and some swedge's looped onto the clips with eye bolts thru the side arm's of the awning.
I like that idea - looks easy enough to make too - thanks for posting
looks like it is on the inside of the awning - does the back of the eye bolt threads ever interfere with the brackets that snap into the back of the main beams of the awning?
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-02-2012, 09:38 PM   #3
trudinator's Avatar
No. There's only the thickness of the nut inside the awning frame.
Old 04-02-2012, 09:44 PM   #4
sherdep's Avatar
ah ok - thanks for the clarification
awning
