Old 01-11-2017, 08:04 AM   #11
Looks like it is "Dual Fuel"! Youroo!!
Old 01-11-2017, 08:09 AM   #12
Originally Posted by KyDan View Post
Follow up. It looks like you got an LP gas genny.
I wonder about that.... LP is going to cost more than gasoline I believe but
you don't have to worry about a carb gunking up while the genny is
in storage so there's that up side.
Every generator I've ever owned has fuel cutoff valve. Just turn the valve and let the generator run out of gas in the engine.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 01-11-2017, 08:49 AM   #13
It will run everything in your camper just fine.
Folks have been using generators just like yours for years for everything from home use (think off grid Alaska) to Emergency Med Services.
Yes, noise will be a concern but you've addressed what your intentions are for that.
Stay true to your intentions and you won't make others mad should you decide to drag that out in a campground.
As youroo said, if you have a Electrical Management System in your rig you 'may' need to explore the 'Edison Plug' which will allow the EMS to work with the generator's floating neutral.
EDIT:
Remember, when running off propane, the wattage will be slightly less than when on gasoline.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 01-11-2017, 09:11 AM   #14
Usually Confused Member
emm-dee's Avatar
EDIT:
I keep hearing that but don't understand why. Are you saying the engine runs at a lower RPM when using propane? If not it seems to me that if the engine is running at the same RPM then the generator would have the same output. If the driveshaft is spinning at, i.e., 3,600 RPM then the generator wouldn't care if the shaft was driven by an engine or 40 hampsters running in a rotary cage.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 01-11-2017, 09:16 AM   #15
Gasoline has a higher energy density so you can run longer on a gallon of gas compared with a gallon of propane. The output power of the generator won't decrease if you run on propane, you will just use more of it.
Old 01-11-2017, 09:17 AM   #16
KyDan's Avatar
Mine too but with the ethanol gas we have now it's not good to store more than a few months so when I'm done with mine-
I shut off the gas and run it until it misses. I turn on the choke and it
runs a bit longer then dies.
Mine has a carb bowl drain so I drain the remaining tablespoon of gas
out of the carb that you can't get just by running it with fuel shut off.
Then I remove the gas line from the carb and stick it into a 5 gal container
and drain the tank.
It's a big hassle but since we only use it for emergencies that's my routine.
LP I guess I wouldn't have to do all that....
But that week we needed it in hot weather I ran thru at least 3 5-gal cans
of gas. I have means to siphon gas from either my truck or one of the cars so we could go longer even if the local gas stations were in-accessible due to weather or lack of power at the gas station.
Everything's a trade off.
That dual fuel sounds interesting! I guess I never heard of that...
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44, 2017-36
Old 01-11-2017, 09:20 AM   #17
and drain the tank.
Stabil will help keep your gas usable longer. I use it will all my portable gas containers.
Old 01-11-2017, 09:28 AM   #18
It's all about the efficiency of the fuel.
Propane is less efficient than gasoline and therefore won't 'react' to loading as well as gasoline especially as temperatures get colder.
You are correct when referring to the genny purring along at 3600 RPM it really doesn't matter what is powering it at that point.
But it is when you introduce a load(s) to the generator, as to which fuel can react better to keeping it purring at 3600 RPM. Propane simply cannot as it's BTU's per gallon (combustion power) is less than gas. Simply put, a propane powered engine just doesn't produce as much horsepower as a gas fueled engine, therefore the derating of the wattage.
Old 01-11-2017, 09:41 AM   #19
NMWildcat's Avatar
Non-inverter generators will NOT 'eat up' electronics if used properly. The danger lies in that the power they provide can fluctuate, especially during start up and shutdown. Which is why instructions say to turn off breakers during these times, although very few folks actually do that Some electronics will not handle power fluctuations well.
Inverter generators always put out clean, steady, power due to design so you don't have the power fluctuations.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 01-11-2017, 09:48 AM   #20
Dmaster79's Avatar
I have the smaller Champion open frame we got from TSC. I think it's 3500watt but only 30amp. Ran many times last year to power our 266rr toy hauler when boondocking. Just made sure ac was off before stopping or starting generator to avoid any issues but otherwise the champions are a great choice.
Dmaster79 is offline   Reply With Quote
generator
