Old 07-11-2014, 01:56 PM   #31
I fixed it. I had pulled these off a job site and forgot that they were set for commercial electric heat. I went in the menu and reset for my needs and it works perfectly now. Thanks everyone.
I set it in the menu settings for 1-0 which is electric/gas heat and A/C
then in the other menu for type of heat I set for conventional gas non 99% efficient model.
I also set a delay on my a/c compressor and set my min and max threshold on a/c and heat. Now I can set the t stat on auto and if it gets too cold at night it will kick on the furnace and then bring the a/c back on in the morning.
I did not bother with a timer programmable one mainly cause I got these 4 honeywells for free from a job I did recently, and a timer one seemed a little bit of over kill for a camper even if I do live in it. haha.
~ Ryan
Traveling Network Field Technician
http://travelingtek.com
I also do a reality show on YouTube about radio control vehicles.
http://lifeofanrcaddict.com
Traveling Tek is offline   Reply With Quote
Old 07-11-2014, 02:04 PM   #32
2005 Fleetwood Pride 38RL
I love the idea of a tstat that will automatically switch from cool to heat to cool. that is really cool (or nice)!
Glad You have it running correctly. Happy Camping!
BBDAWG is offline   Reply With Quote
Old 07-22-2014, 11:00 PM   #33
blue river's Avatar
Honeywell programmable model #
Originally Posted by BBDAWG View Post
For a 2014 model Honeywell RTH2300 to Coleman Mach A/C
As of 06-01-2014, these settings are working.
(FYI, I had another Honeywell Stat, digital, 5-2, that did not have the hg/he switch and it would not work. I might have given up to quickly, but it did not have the needed switch, so IDK)
The final working wiring is set as follows:
A/C side Stat side
White to white - Heat
Yellow to yellow - A/c comp
Green to green - fan (low or hi)
Grey to green - fan (low or hi)
Red to R/Rh (leave jumper on)
Blue not used
All other connections on the Stat are not used.
The switch on the back of the Stat should be set to "HG" (or gas heat)
Many thanks to gljurczyk and sdelam and Triguy for their excellent help!
Can you provide a photo of the thermostat you installed? A quick web search found a RTH2300B 1012/A....is that correct?
blue river is offline   Reply With Quote
Old 05-06-2015, 12:50 PM   #34
tman53's Avatar
Honeywell Model RTH111B
Been looking at changin out my Coleman-Mach analog to a digital Thermostat and have read through your thread...lots of good info there!
I have a simple Honeywell stat (RTH111B) and pretty much understand how to install it but...I'm a bit concerned that the blue wire is not being used as noted in your post. According to the literature I have the wires are as follows:
R= Positive or power
Y= A/C Compressor
W=Heat
Green=High speed Fan
Gray=Low Speed fan
Blue= Negative/Ground
So if I don want Low speed I won't use the Gray wire but how will the system work without the blue to complete the circuit?
I don't want to start cutting wires until I know the stat i have will work.
Thanks!!
tman53 is offline   Reply With Quote
Old 05-06-2015, 01:03 PM   #35
Witch Doctor's Avatar
Y= A/C Compressor
W=Heat
Gray=Low Speed fan
Thanks!!
Do you have a "C" terminal on the new sub base? If you do that would be common or ground. Is battery operated? I'll try and find something on your new stat not all will work.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-06-2015, 01:23 PM   #36
Call 1-800-468-1502, I would say blue is common or ground, The details do not go into it. They will tell you if it will work and how to wire it. It has 12volt back up for the display already. If it will work off a milli volt as they said it should work. But millivolt you only use red and white no ground. It's switch is set for gas already and leave the jumper in from R to RC, just use the R for your wirer.
Old 05-06-2015, 01:54 PM   #37
tman53's Avatar
Just tried calling the Honeywell help line as suggested. They were of no help. Basically they said the thermostat would not work on an RV.
Guess I will just cut the wires and start trial and error method cause I know this will work. :-)
Old 05-06-2015, 08:55 PM   #38
offroad's Avatar
On mine, Blue was +12v which you won't use.
Red, White and Yellow wires from the RV are connected to R, W and Y terminals on the Thermostat.
Green and Gray are for high and low fan, whichever you want goes to the
G terminal.
You can follow the link below to see mine, if you want to wire up a high/low switch like I did.
Black - Honeywell Digital Thermostat
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 05-07-2015, 01:29 PM   #39
Canadian Member
itat's Avatar
offroad, in the thread you referred to, is the 2nd picture a before and after showing how you had to trim the plastic around the mode selection switch to allow for room for the SPDT switch?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 05-08-2015, 01:00 PM   #40
offroad's Avatar
Yes, that was before and after pics.
Probably didn't need to remove quite that much material for the switch and wires, but it didn't hurt anything.
Using the A/C this weekend and really appreciate the lighted dials on these.
You just press up or down by feel, and it shows the current setting then you can adjust. No need to turn on a light in the middle of the night if I wake up and am too warm.
