Old 04-08-2012, 03:16 PM   #11
GASPEDDLER's Avatar
Nice job!
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 04-08-2012, 05:54 PM   #12
Nice job.
After checking out a lot of RVs at the last RV show, most dealers or manufacturers are using two 1" wide Velcro straps attached to a bracket to tie down TVs. This is what I did for ours. The struggle I had was finding brackets to attach the Velcro to. I tried to find out from a couple of local RV dealers but they were hopeless. I ended up getting a couple of plastic ones from THECLIP.COM - Better,... (under "the clip mount" on their site). They are made for a 1" wide strap.
I'd post a pic of our TV mount but we are actually just camping at the moment. If you can wade through all the photos in "My Photos" you will see a photo or two of what I did for the mount + Velcro tie-downs.
BTW, you don't say what size or weight your TV is. I'm wondering if you might want to structurally secure the sidewall section (that the mount is attached to) to the ceiling trusses. I've read that cabinets can fall off walls if too much weight is added.
I hope this helps.
PS: It also took me a 2nd mount to get our setup to work. I initally bought a locking articulating mount from CW and it turned to be a piece of junk. I highly un-recommend it.
myredracer is offline   Reply With Quote
Old 04-09-2012, 03:37 PM   #13
vasnipe's Avatar
myredracer, thanks for the tip on the clips. That gave me another idea to try, now another trip to Home Depot - for the bolt/nut covers and the other items for the strap. I'll let y'all know what I come up with.
The new TV is a 19" diagonal LED Curtis model LED1930A LED1930A | Curtis 19" 720p LED HDTV | hhgregg
It must have been on sale when I bought it, only $119 vice the $139 they are asking now...
The TV mount is rated for a max of 80 lbs, so hopefully it will be able to handle an ~10 lbs TV hanging off of it...
As to the weight - Per the HH Gregg web site the TV weighs 9.3 lbs. Much less than the 19" TV/VHS VCR CRT combo that used to live in the cabinet. God alone knows how much it weighed, but I have its twin back in the bedroom to upgrade next. The smaller/shorter mount I ordered at first will work OK for that.
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 04-16-2012, 01:59 PM   #14
Don't forget to think about the weight of your articulating mount. The one we got weighs 11 lbs. You could have over 20 lbs hanging onto the cabinet sidewall and bouncing up and down while travelling. I screwed 3/4" plywood into the ceiling joists (two of them) and some 2" screws through the sidewall into the 3/4 ply. Easy to do - cheap insurance. Our 19" TV has a built in DVD player so has a little more weight overall. From anecdotal comments I've read about how cabinets get affixed to walls, I just didn't want our TV and cabinetry ending up on the floor.
I also used a little bit of red Loctite on the four screws holding the plate to the TV. Even more insurance....
I just noticed that you have a large mounting plate attaching the TV to the arm (for 100x100 or 200x200 screw spacing). It looks like you are blocking air ventilation? This is what I ran into on ours. I simply used an angle grinder with cutoff wheel and trimmed the excess off and touched it up with black spray paint.
On our first camping trip out this year, our fancy-dancy new TV did not work when hooked up to campground cable TV. Having just installed the TV, I pulled everthing apart to check the co-ax fittings I installed. Nothing helped. Then I turned off the amplifier. Got it. Leave amplifier off if hooked up to cg TV.
Old 04-16-2012, 08:11 PM   #15
vasnipe's Avatar
We took the camper out this weekend to Dam Neck, VA, great trip to be with son. We had so much fun with other activities we did not even rig the TV for viewing.
I did not weigh the mount prior to hanging it and of course they don't list a weight in the specifications, I think I'll sink a couple more screws into the overhead as insurance as you suggest. I noticed the outsized mounting plate and thought about trimming it down, if it becomes an issue I'll take that for action. Thanks for the suggestions and I hope your rig works out for you as well. This is one of the reasons I like the forum here, suggestions and comments can and do help out.
Chris in Virginia
Old 05-05-2012, 03:24 PM   #16
Chris,
Thanks for the great pics and explanation of your install. My 2011 Sunseeker was just broken into and all tv's were stolen, including the mounting brackets/arms. I can't find the exact mounting arm to replace the one that was in the bunk (same location as your project), so unless I find one soon, I'm beginning my version of your project.
Sam in Illinois
hailto is offline   Reply With Quote
Old 05-05-2012, 07:17 PM   #17
vasnipe's Avatar
TV mount
Sam, my condolences on the break in. That is a violation of the psyche if not the person. Good luck with the new arm and mounting. Just remember to allow for the length of the screws and bolts to reach through that empty area and grab your backer board. Mine survived the trip last month to Virginia Beach, never even got pulled out for use... But then again, all the potholes on I-264 didn't even budge it from position.
Old 05-05-2012, 09:10 PM   #18
jd-ford-hd's Avatar
Hey Vasnipe, you stated the first mount purchased was $13.78 qty. of 50 and second mount purchased was $28.28 in qty. of 50. Does this mean you now have 99 tv mounts to get rid of..?!?
"IF IT AINT GOT A MOTOR, I AINT INTERESTED"
jd-ford-hd is offline   Reply With Quote
Old 05-06-2012, 06:45 PM   #19
vasnipe's Avatar
Extra TV mounts?
No, Boss!
Sorry, no extras for sale. The way their link parsed it made it look like I bought a truckload of the things.
Old 05-19-2012, 06:48 PM   #20
vasnipe's Avatar
Mod complete
Today after the yard work and other chores I had some time to complete the strap to hold the television and arm in place for storage and travel.
I got the Finishing Washers and #10 screws from my local Home Depot. The nylon strap was a backpacking sleeping bag strap bought at Walmart many moons ago. The cheap ladder locks broke on the second use so I kept the straps for other uses (like now). The buckle is available at most sewing or craft stores in the Notions section. I happened to have this one on hand from another project. I doubled the ends of the strap where the screws were to go through and used my wife's sewing machine to stitch around the edges and diagonally. Not the prettiest or most straight, but it won't come apart any time soon. It so happened that the television had a notch in the center of the bottom back section that the strap fit through nicely, stopping side to side movement. Running the strap vertically provides support for bumpy roads.
Strap before stitching
After doubling and stitching
I doubled and stitched the ends next to the buckle to prevent fraying
tv mount
