Night light for Door
Just eliminated the need to add a light by the door. I installed a remote control on the porch light that works great. Just opened the control panel and found a 12v hot wire, stripped off a spot, soldered the 12v In wire from the remote, stripped off a spot on the 12v lead to the porch light, soldered the 12v Out wire from the remote, connected the 2 ground wires from the remote to the ground bundle behind the control panel and everything works great. Control panel porch switch will turn the light on/off as normal and if the porch light is off, I can turn it on & off with the 2 remote key fobs. Only thing is that if I turn it on with the key fob, I have to turn it off with the key fob, but don't see that as a problem.
