Old 06-02-2013, 08:07 AM   #1
No Flow-Low Flow-Valve
Here at the R&D Center of Youroo Corp. The famous anti-freeze 3 way valve,what a JOKE! The flow rate is super restricted,people who complain about water press-flow rate,ect. look at these Pics. (The valve),(Hole size in valve,copaired to incoming hose size-with drill bits to show comparison). The actual size is (incoming-.469),(Valve-.294). The real Restriction is thru the inside of this valve (1/2 of .294) = .147 now is that a good number? Youroo!!
ID:	31971   Click image for larger version
ID:	31972   Click image for larger version
Old 06-02-2013, 12:02 PM   #2
I thought lots of people had this valve installed on their units? Maybe not. Youroo!!
Old 06-02-2013, 12:18 PM   #3
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Do you think it might have been designed that way to limit the consumption of water when boondocking?
dimurrrw is offline   Reply With Quote
Old 06-02-2013, 09:26 PM   #4
No the valve is for pumping anti-freeze into the water system using the on board 12V pump.The way it is made restricts your water flow every time you use your F/W system the rest of the Year. People are on here all the time asking about low pressure & low flow rates,the first thing they are told is (Remove the restrictors) from their (Kit.,shower,and bath faucets. What this valve does is restrict the flow on the suction side of your Pump,not a proper way to control water pressure or flow! Youroo!!
Old 06-04-2013, 10:01 AM   #5
Is this the Valve that was going to be used as a Transfer device for Fresh water tank in another Post? Herk was going to research it? Youroo!!
Old 06-04-2013, 11:30 AM   #6
jtstromsburg's Avatar
I used my winterizing valve to add fresh water. I don't know what my actual valve looks like as I have a panel in my fiver that has the handles on one side with the actual valve behind it and I haven't looked back there.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
