Old 09-16-2019, 07:15 AM   #1
No More Extension Cords!
Finally got 30 amp service box installed. Replaced unused 20 amp breaker with 30 amp breaker in house service panel, ran 10/2 wire to service box. Goodbye extension cord!
ID:	215105   Click image for larger version
John and Janis Blaskowski
The fur-kids; Pedro, Penelope, Chico
Macomb, Michigan
2013 Ford F-150 XTR 3.5L Ecoboost Max Tow Package
2010 Rockwood Signature Ultra-Lite 8315bss
John-n-Janis is offline   Reply With Quote
Old 09-16-2019, 07:31 AM   #2
Nice set up.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 09-16-2019, 07:40 AM   #3
Thanks. A must have for anyone that parks their camper, fifth wheel or motorhome at their house.
Macomb, Michigan
Old 09-16-2019, 07:41 AM   #4
PPST Wannabe
kenandterry's Avatar
Iím just wondering how soon youíll wish it was a 50 amp service box.
Just sayiní
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-16-2019, 08:17 AM   #5
No to rain on your parade but that receptacle needs to be 3’ from the gas regulator. Also, if the steel flex or armored cable to the right is supplying it, the wiring method is not correct for outdoor use. I can’t tell from the photo but it appears the flex may enter the box without a proper connector. Just don’t want someone else to copy the install and create a dangerous condition.
WY Husker Fan is offline   Reply With Quote
Old 09-16-2019, 08:26 AM   #6
cavie's Avatar
Originally Posted by WY Husker Fan View Post
No to rain on your parade but that receptacle needs to be 3í from the gas regulator. Also, if the steel flex or armored cable to the right is supplying it, the wiring method is not correct for outdoor use. I canít tell from the photo but it appears the flex may enter the box without a proper connector. Just donít want someone else to copy the install and create a dangerous condition.
Name:	What he said in that comment up there (1).jpg
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 09-16-2019, 08:40 AM   #7
Thanks for the observation Ken. Did not know about the 3 feet distance from gas regulator. I will re-mount higher to meet 3 feet distance and install PVC conduit to make it right and make it safe.
Macomb, Michigan
Old 09-16-2019, 08:49 AM   #8
gastan's Avatar
X3
I am a retired carpenter and am well versed in code requirements for that field.
For any other projects I undertake I am obsessive about googling code requirements or finding a tradesman of the proper field and asking.
That being said, your project looks great and will be super once the modifications are done. I always admire people who take the time to make their projects look neat and professional.
2012 Rockwood MiniLite 2104
2007 GMC ECSB 2500HD Duramax
gastan is offline   Reply With Quote
Old 09-16-2019, 09:26 AM   #9
frank4711's Avatar
Well Done .... you will enjoy ....
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 32 days camped 2019 *** Predator 3500
frank4711 is offline   Reply With Quote
Old 09-16-2019, 12:54 PM   #10
NXR
NXR's Avatar
Where is that clearance found? I added a 50-amp to the side of my house and the building department inspector said there was no minimum clearance to the gas meter. I did select a spot over 3' away but one place was within a foot and they said it would be approved.
Or is the difference that I have a gas meter that does not have the external "disc" thingy?
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 09-16-2019, 02:31 PM   #11
Please check with your LOCAL ordinances to determine the proper positioning for your local area.
canmes is offline   Reply With Quote
Old 09-16-2019, 02:55 PM   #12
Forbes's Avatar
X-2 couple of times...
I have a State of Tennessee Electrical both residential and commercial plus the county I live in BUT it is not recognized by the City of Johnson City as they have their own set of rules and codes, in fact they don't even recognize Federal Laciness. Ask why once and was told that the locals can require more but not less than the state there fore allowing them to set what codes they want plus you have to pay them $250.00 per year for their new code book that is required for you to have on job site.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Forbes is offline   Reply With Quote
Old 09-16-2019, 07:30 PM   #13
10/2?
!0/2? In Flex cable?
Maybe I'm ignorant, but I thought you would have to run 10/3 in anything but EMT or rigid conduit? But WY Husker Fan and Cavie didn't mention it, so maybe it's allright. I'm pretty sure that if you change to PVC conduit, as you suggested, you will need three #10 AWG conductors.
Not a licensed electrician; somewhat familiar with the codes.
Larry
Larry-NC is offline   Reply With Quote
Old 09-16-2019, 07:38 PM   #14
david_reaves's Avatar
Larry, the 10/2, 12/2, or 14/2 we get here includes two insulated conductors and a "non-insulated" ground wire, so the ground is still there, just not insulated. (I'm not an electrician, either, though.)
... I thought you would have to run 10/3 in anything but EMT or rigid conduit? But WY Husker Fan and Cavie didn't mention it, so maybe it's all right. I'm pretty sure that if you change to PVC conduit, as you suggested, you will need three #10 AWG conductors.
david_reaves is offline   Reply With Quote
Old 09-16-2019, 08:27 PM   #15
Okay...
Okay, but around here that's called 10/2 WG which stands for 10/2 With Ground.
Larry
Old 09-17-2019, 06:30 AM   #16
DouglasReid's Avatar
Just sayiní
When we got our new camper it is 50 amp. Th eold was was 30 amp and I had a 30 amp box.
I spent the time and money to make it 50 amp box. It was a waste of time and money.
The only thing that ever runs is one AC and the 30 amp would have worked perfectly.
LESSON LEARNED!
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 09-17-2019, 07:18 AM   #17
Just sayiní
11 years with a 30A plug. No concerns here at all.
TheWolfPaq82 is offline   Reply With Quote
Old 09-17-2019, 07:23 AM   #18
cavie's Avatar
You are absolutely correct. No RX allowed in conduit in a wet location. Conductors must be listed for wet locations,
Old 09-17-2019, 09:18 PM   #19
kittlecat's Avatar
One of happiest days of my RV ownership was when we had a dedicated 30 amp plug installed at home for my TT. I no longer worry about extension cords, blown fuses, etc. Great job! I like the cover on yours better than the cover that was put on mine!
Kittlecat
"Integrity simply means not violating one's own identity." Erich Fromm
"You have to understand who you are to know who you are not." Anonymous
"Know yourself, know your world. Change it." Anonymous
kittlecat is offline   Reply With Quote
Old 09-17-2019, 10:02 PM   #20
frank4711's Avatar
Yes for sure ... we are new to camping and I had a 50 amp installed ... not a big deal but installer had to add a 100 amp panel inside off main panel we have had to many add-ons after 20 years in this house ... I wish I had skills to do but I stay away from electrical projects ...
