08-05-2017, 08:39 AM
No More Going Outside
Well I finally got around to modifying my stove vent flapper...and I can now open and close/lock it from inside. I used #8x32 threaded rod. Pictures from top to bottom:
Outside view of flapper closed.
Outside view of flapper open.
Inside view of rod in closed and locked position.
Inside view of rod in open position.
View of rod routing under the stove hood.
08-05-2017, 08:51 AM
I hate to be negative, but this looks like a solution looking for a problem. When you're camping, air flow and gravity take care of opening and closing. The only time you need to go outside is to lock it for travel and unlock it when you get there.
Gary
2017 Cedar Creek Silverback 37MBH
2008 Dodge Ram 3500 6.7L, DRW, 4.10 Rear end
08-05-2017, 12:46 PM
My outside vent is to high off the ground so the flapper stays open all the time
08-05-2017, 01:20 PM
I always fine a way to lock to from the outside when there is nothing close by to get up on. Just something like a back scratcher does the trick. If push comes to shove I get the old man to do it.
But if you are short and don't have any other options, this would work.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
08-06-2017, 06:06 AM
Camper
Why does the flapper need to be "locked" for travel?
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
08-06-2017, 06:20 AM
DW's 401(k) Plan
Older units would eventually have the flaps fly off going down the road. The newer units seem to be better engineered to keep this from happening. And, yes, I had one "get lost" years ago.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
08-06-2017, 06:44 AM
We lost one of ours on a previous trailer.
I put tiny brass "jewelry box" hinges on this one so it's not coming off.
We still lock it when not in use because it will inevitably flap and tap, tap,
tap during the night if there is much of any breeze.
I have to use a fly swatter handle to reach the locking tabs.
Peace!
Dan & Rita D
08-06-2017, 06:57 AM
No more going outside
BGKirkham...In your case that may be true, but we usually have grandkids traveling with us and they are notorious for getting hungry late at night or really early in the morning...sometimes in a downpour. We keep the flapper closed to eliminate a path for flys, mosquitoes, and bees from geting in. Remember even when not using the vent for cooking, if it is not held closed it will open whenever the A/C or furnace is running. So for us the mod is certainly welcome.
08-06-2017, 07:06 AM
Lost ours on a previous motorhome.
08-07-2017, 04:11 PM
Our old MH, a 89 Winnebago Cheifton, Had a slide lever that opened the vent and turned on the fan. That was a much better design than the plastic ears to lock the flaps on newer vents.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
08-07-2017, 04:22 PM
Frank
I wish they still made them like that.
08-07-2017, 04:30 PM
On every camper we have owned, the vent allowed the exhaust fan to expel smoke, cooking smell. No bugs can get into the camper unless they eat the aluminum filter. I torn the doors/flapper off all of the previous vents and throw them in the trash. End of the stupid flapper.
08-07-2017, 08:02 PM
Well, this is something I didn't know about, I reckon I will see if the flapper is still there or if the locks work. Or if I need to...
9.5 year old FR Cherokee 295 WP 32' toyhauler
2013 Ford F250 SD CC 4X4 4.30 gears
Tuned-- engine, music, and exhaust,
