Old 02-02-2016, 04:45 PM   #1
Onan Remote Oil Drain Mod
Changing the generator oil on my 2014 SS1913 toy hauler has been a massive chore. The Onan 4K is mounted in a side cabinet in such a way that the drain plug is directly over the trailer's I-beam frame. Directly below the frame are the grey and black dump valves. Even with a second set of hands helping, it's impossible to drain the oil without a decent amount getting on the frame, valves and concrete below.
This past weekend, I built an extension for the drain plug and routed it outside where it's easily accessible.
Before I drained the oil, I picked up the parts and built the original elbow fitting using 1/4" NPT as per literally EVERY online source I could find for the Microquiet 4K model. When I attempted to install the elbow, I found out that it's NOT 1/4 - but an M12x1.5 bolt. That's right - Metric. Back to the hardware store....
I picked up a M12x1.5 to 9/16th flare adapter and a 9/16th JIC flare to barb elbow to replace the 1/4" stuff, and several inches of heat and oil-resistant hose.
On the other end, I added a ball valve and safety cap and secured the valve to the frame with a padded hose clamp.
Next time I change the oil, all I have to do is remove the clamp and cap, and open the valve.
I hope this helps someone in a similar situation.
Just me, my girlfriend and our crazy Boxer Stella.
'13 GMC 1500 Sierra Denali, '14 Stealth SS1913, '08 YFZ450 with some crazy engine mods.
vocoder is offline   Reply With Quote
Old 02-03-2016, 08:51 PM   #2
Technorick's Avatar
Nice work! EZ oil drain makes a factory version with a drain hose and cap. I installed one on my DS30 FR3 motorhome this fall.
2014 FR330 DS
Technorick is online now   Reply With Quote
drain, modifications
