Old 07-29-2012, 05:43 PM   #1
Night Stone's Avatar
Ongoing mods/add-ons
First is the stick on level bubbles, finding a place that is visible and inconspicuous.
Looks like I have to move the one on its side to a parallel surface to the ground
as its not quite telling me its leveled
If it falls off, I will get the screw on ones later.
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 07-29-2012, 05:59 PM   #2
2nd Mod
Finding where to put the FRF and Frog stickers, since I have no rear window, and stickers don't quite stick to the new finished the trailer has. So I came up with a solution and here is my mod:
parts cost: 9.72 for metal strip bar, pre-punched, 7.81 for the clear smoked plate protector and package of nylon screws.
Cut to length
Back Side
FRF and FROG member
This Space for Rent
Old 07-29-2012, 06:00 PM   #3
Finished product
Installed on Travel trailer
I will add a stick on foam backing behind the plate so its not too flimsy or causes damages to the trailer wall
FRF and FROG member
This Space for Rent
Old 08-11-2012, 09:35 PM   #4
Smile 3rd mod/add-on
I added these bug screens to prevent bugs and critters from going inside
This one for the furnace vent
This one is for the water heater vent
And the last one is for the refrigerator vent and a great fit too, will add more plastic ties to hold the rest of it up as it came with 6
enjoy
FRF and FROG member
This Space for Rent
Old 08-12-2012, 07:05 AM   #5
golfmedik's Avatar
It's fun to do all of those mods, and then go camp. But then you will think of others that you see or hear about that you will want to do as well, it's endless. But I wouldn't trade it for the world. Nice work and happy camping!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 08-12-2012, 07:37 AM   #6
Herk7769's Avatar
Word of caution on the Fridge screens.
Make sure you keep them clean.
A LOT of air flows through them and if the get dirty it will restrict air flow.
Also you with screens on the bottom, you will need screens on top (to bug proof the chimney) as well.
Keeping them clean is also a chore since it involves a trip up on the roof; removing the cover; checking/washing the screen; and re-installing/caulking the cap.
HAM CALLSIGN - KC3FFW
Old 08-12-2012, 11:28 AM   #7
Thanks for tips, the door for the fridge is easy to clean, remove it from trailer and wash it down.
As for the chimney part, I don't think I ever saw a picture of that mod on this forum or a part to use? Must have missed it
or did you mean this vent
FRF and FROG member
This Space for Rent
Old 08-12-2012, 04:59 PM   #8
Terier's Avatar
Thanks for the pictures of the FRF sticker and license plate holder. It's easier to picture now.
Old 08-12-2012, 05:08 PM   #9
Put alum screen wire on the back of the water heater vent, outside door for refrigerator and completely covered the area between the ac condensor & evaporator under the cover. Here in NC, the dirt daubers are thick and build everywhere. Discovered a dirt dauber nest on a blade on the ac fan this winter in FL when we turned the ac on. Terrible vibration. 1 hr on the roof in 90 heat convinced me not to let it happen again.
Old 08-12-2012, 05:42 PM   #10
Md Jeff's Avatar
They're like that in Md too; Had to pull the furnace on the last camper due to Dobber nests........if there's a opening, they will find it.
Md Jeff is offline   Reply With Quote
