04-25-2012, 10:11 AM
Steve Jackson
Outdoor Grill
Has anyone connected a extension hose on the one that comes out of the side of trailer? My wife refuses to let me hang the grill on the trailer. It has the quick connect fitting so is it safe to put an extension on this. I really like the grill and want to use it.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
04-25-2012, 10:22 AM
As long as its the grill that came with your trailer or it's one made for high pressure you should be able to just get an extension hose with the appropriate fittings and length you need.
2012 Rockwood Signature Ultra Lite 8312SS
2008 Rockwood Roo 21SS (History)
1981 Starcraft Galaxy 2108 (its gone )
1999 Dodge Durango (Retired TT)
2006 Dodge Ram 3500 Quad Cab 4x4
04-25-2012, 10:25 AM
Not sure why she refuses but my last tt had one and we hung it on there for 6 years with no issues. No discoloration of tt either.
It really doesn't burn that big of a flame.
If you do put an extention make sure its propane hose.
we liked ours so much I kept it for our 5er.
04-25-2012, 10:28 AM
If you are referring to the RVQ-type of grill, check the grill itself - some of them are manufactured to mount on the arms of the trailer side rack only, and will not sit properly on a table. If you can set it on a table, any propane dealer can provide an extension hose with the correct fittings on it.
...VTX-Al
04-25-2012, 10:31 AM
Steve Jackson
Can't understand why either Turbo, I will continue to try and convince her. I will have to show her your post. This last weekend I had it on a table next to the trailer and it was probably as close as it would have been hanging on the mount. Do you put your awning up while you use yours? Not sure how the awning would hold up to the rising heat.
04-25-2012, 10:32 AM
...VTX-Al
Yes normally the propane fitting comes out the bottom and won't sit on a table.
Besides there air holes on the bottom
04-25-2012, 10:35 AM
Steve Jackson
The mount that came with my grill can be used either on the TT or table top. The grill has both horizontal and vertical hole for the post to go in.
04-25-2012, 11:23 AM
We used our grill all of last year with it hanging on the bracket on our TT. We also had our awning out when doing so. No grease on the TT or the awning. And no discoloration, excess heat, etc. on the TT either. If FR and other manufacturers believed this to be some sort of dangerous situation, or they received tons of complaints regarding stains, grease, finish problems, etc., they would have changed the design long ago. I just add this one to my mental file entitled "if it ain't broke, don't fix it."
2012 Rockwood 8293RKSS
04-25-2012, 11:24 AM
I don't want to hang the grill on the side of the trailer either , just my own personal preferance. I went to Tractor Supply Store and got an extension hose that fits the quick connect and is 10feet long so I can get it out from undr the awning.
Barry & Anita Rowe
2012 Flagstaff 23FB
2003 Ford F-350 5.4 for future larger TT
Nites Camped in 2011:32 Nites Planned in 2012:35
Nites Camped in 2012:23
04-25-2012, 11:27 AM
Now a "Top Member"
I used my RVQ with my Travel Trailer all the time for the 5 years we had it. Under the awning, with the awning up, even with the TT windows open. We never had any problem with it. It doesn't get hot enough towards the trailer or up to the awning to do any damage. If I had one on my 5th wheel, I'd be using the heck out of it as well. Tell the wife (not that it will help any) that it will be fine. I can post pictures if she wants a visual.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
04-25-2012, 11:30 AM
Steve Jackson
I'm with all you guys on this. It's just the lovely wife I have to convince.
04-25-2012, 11:32 AM
Used it with awning out as well!
04-25-2012, 11:35 AM
We've used ours the same way trudinator every since we got our 08 Flagstaff and have never had an issue with the side or power awning which we always have out (staked down). Made an extension hose to be able to set it on a table, but seldom use it as it just takes up room on the table and creates a tripping obstacle which us old codgers don't need. Don't like the new 5ver hook up as it is under the camper. Will eventually plumb it so it comes out the side.
