Old 08-24-2012, 11:30 AM   #11
Originally Posted by ironj View Post
...and the door would have to open and swing IN towards cabinets/sink area thus eliminating the possibility of having anything permanantly mounted in the swath the door would cut costing you about 2ft of counter in an already somewhat cramped setup...
I was suggesting installing the 2way against the back wall with the SIDE of the frig against the back wall and the door opening out towards the outside of the trailer. The venting could still be done out the back by building a curved or angled chute. Access door for the bottom would be small, but possible.
Old 08-24-2012, 12:12 PM   #12
ironj's Avatar
yeah, i understand what you are saying...and i agree...that would be ideal......BUT, again we go back to venting...an "angled chute" as you suggest would not be sufficient...remember a propane fridge not only needs ventilation, but an area for heat extraction and dissapation. As i understand it, due to building code, you cant vent the heat into a closed compartment (and i certainly would not want the only thing between a propane heater and my kids in the bunkhouse to be a piece of luan....vented or not)...
given that, the only soultion i had to offer was to use a fridge with the cooling system on the SIDE of the fridge vs the back...which no one makes of course, but hey...its an idea?? LOL...
for the record i have seen 2 way fridges in the back of toyhaulers and such....but i have NEVER seen one either original, aftermarket or otherwise mounted in an outside kitchen type setup.....the fact that outside facing doors are required pointing the cooling system TOWARDS the trailer interior is the issue at hand....
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 08-24-2012, 12:40 PM   #13
yeah, i understand what you are saying...and i agree...that would be ideal......BUT, again we go back to venting...an "angled chute" as you suggest would not be sufficient...remember a propane fridg...
A couple of fans would fix that problem with them interconnected with the burner. Fan doesn't energize and blow, no gas valve opens, similar to the sail switch on the furnace.
Old 08-24-2012, 02:50 PM   #14
ironj's Avatar
thats something that could be done by the end user...but would never happen from the factory...too much left out there in terms of potential liabiilty if regardless of how small in probability...
and i wonder how large the fans would have to be in order to extract the heat generated by those fridges....i know mine gets WAY hot in the coil area while on propane.....or how loud they would be?? and also how fast would the batteries last in doing so in a dry camping situation before the whole thing shut down?
the only way i see that even remotely happening is if the back of the unit is encased in a fire proof metal housing seperated from the trailer innards....on top of the fridge cost, i can only imagine what weight and fabrication cost this would add to the trailer for the end user...
again, im not disagreeing with you that a 2 way would be optimal, but as a business owner myself, i tend to look at the hows, whys, and potential profitibility of any change....and on top of that if the AMMOUNT of profit justifys the AMMOUNT of investments on my end.......we as owners want the manufacturers to take care of us, but in reality at the end of the day its a balancing act of making something the MAJORITY of people will like while still keeping their profit margins...
in this case, it seems to me that while a 2 way is definantly doable, the manufacturers have decided that the ammount of investment on thier end to build the unit to code, and justify that investment with the potential of increased sales or profitibility was just not there....i do it all the time....why spend 100k on something you will only make 5k on over a 5yr period?? yes its nicer, better, smarter, but ultimately i want to have a 10% ROI or better...anything less is just bad business....
sorry for the tangent...LOL...im at work and i guess my mind is on friday profitibility stats!! haha...i need to go camping!
Old 08-24-2012, 03:03 PM   #15
The frig compartments are sure not fireproof on the regular rv frigs. Just 1/8" luan. If I had an outside kit. and did the frig mod, I would fab the rear compartment out of 0.030 alum sheet or some 20 or 22 gage steel sheeting.
Old 08-24-2012, 03:09 PM   #16
ironj's Avatar
no they are not.....but also the fridge innards are not sandwiched between the back of the fridge and an interior wall.....the opposite side has that fairly large louvered vent open to the outside...and even with that exposure and surface area, some units have MULTIPLE cooling fans on the exterior coils ....
22ga steel would be a good start....but remember we are talking about a trailer that barly has a 22ga frame and the rear bumper cant hold a bicycle!! LOLOLLOL.....sorry....that was funny to me!!
Old 08-26-2012, 08:45 AM   #17
RPAspey's Avatar
found it!!!! here's the link, looks like they turned the fridge sideways and vented out the back.
http://www.riversidetrailer.com/LP_Refrigerator.html
hope this helps.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 08-26-2012, 10:28 AM   #18
ironj's Avatar
Yep...thats the only way i can see it working....frig innards vented out exterior wall.....although as we were discussing before, in that situation you lose the cabinet where the door opens as well as functionality of the counter as well......unless you want to move everything off the counter when u want to open door.....
Im sure there are some who would be willing to make that sacrifice for a 2 way outside.....and i think its cool that at least they OFFER it as an option.......
Any idea as to cost?..... it says 'optional'......so i am just curious what they set as the price point for that?....
Old 08-26-2012, 10:33 AM   #19
Could still mount the side against the rear wall and angle or curve the chimney to the rear with a furnace type transition and a low rpm duct fan. Not a big task, and it would eliminate the cabinet door problem.
Old 08-26-2012, 11:56 AM   #20
ironj's Avatar
actually i fired off an email to dometic asking about this, and thier reply was it was not a recommended installation scenario and they could not offer advice on it and i should referr to the install tech notes....(which screamed liability concerns to me)
they gave me a pdf link.....didnt read the whole thing....but seems like dometic preferrs an "open air (facing outside of trailer) vent", with a cross section of 400cm on the condensor and absorber....
1. Another unfavourable method of rear installation
is to install the air intake and exhaust grilles at the side wall of the recreation vehicle. The air-heat recirculation is very restricted which
means that heat exchangers (condenser, absorber) cannot be adequately cooled. The optional
method of an additional air vent grille installed in
the floor also exhibits an insufficient air flow duct..
(seems they dont recommend cooling vents originating from the floor either)
i dont know...but it seems like to me we arent going to see a MANUFACTURER offering a fwd facing 2 way fridge any time soon.....
like i said before.....could they??? PROBABLY.....hell COULD THEY have put a ladder on the back of my lacrosse 318bhs???? PROBABLY.....is there any way to do it NOW that would work without MAJOR modification???? NOPE.....gotta love the logic they use sometimes....
