Forest River Forums
Sunline User Photos
Old 07-19-2011, 09:30 AM   #1
RubenZ's Avatar
Outdoor Shower & Low Point Drain
Ok, Talk to me about how these Low Point Drains work. My Puma 23fb has them and I really would love an outdoor shower on our trailer. I've got an idea of modifying some faucets to them or valves to connect a coil hose to for rinsing feet, cleaning pots and pans from the BBQ pit etc so I don't have to walk around trailer and do it by campsite water supply. My question is are these drains even pressurized? I don't understand how there would be water pressure if they are just drains. Or is it more complex? Do they get the pressure from the shore water and since the valves would be open while in use, would allow the pressurized shore water out the hose I add?
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 07-19-2011, 09:37 AM   #2
prof_fate's Avatar
when you turn off the water to the trailer there is still water in the hoses and pipes. The fill point/ city water connection is not the lowest point so when winter comes or you sanitize your system and then need to drain out all the water you need to open the lowest point - that's what this is, the lowest point of any hose/pipe so that you can drain out all the water in the entire trailer.
Jill & Chris, Wills (11) Evie (8) & Toby our collie (2)
2011 Grey Wolf 28BH
2001 Expedition EB 4x4 w/ Reese StraitLine Dual Cam, 5.7, 3.55
Nights camped 2011: 11 2012: 0 (so far)
prof_fate is offline   Reply With Quote
Old 07-19-2011, 09:40 AM   #3
RubenZ's Avatar
Ok, I understand that part, but how does work when people say you can use them for an outdoor shower. I'm guessing its like you said that when I have shore water on, the pressure goes out somewhere, and that would be the low point drains if they are open right?
Ruben Zamora
Old 07-19-2011, 09:50 AM   #4
Fire Instructor's Avatar
Ruben,
It's relativly easy to cut into your water supply and add an outside shower. You can purchase the kit on-line, and just install it on the outside, wherever you have H & C water running nearby inside. You can purchase "aligator tooth" fittings for the PEX pipe or youu can purchase a crimper and crimps. Some tool rental outlets will rent you a crimper, saving your costs even more. PEX pipe and fittings are available at Home Depot and Lowes, so don't have to pay RV prices for them.
Be safe, and Everyone Goes Home!
Fire Instructor
2004 RAM 1500 4x4 Quad Cab w/Hemi, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 07-19-2011, 09:52 AM   #5
prof_fate's Avatar
the drain is on the cold water only I believe.
2011 Grey Wolf 28BH
Old 07-19-2011, 09:58 AM   #6
RubenZ's Avatar
Originally Posted by Fire Instructor View Post
Ruben,
Ya I may just do that. I had originally thought to actually cut the side of TT and add it right but I'm so scared to do it LOL. TT is just a month old. I'm guessing that since our Bathroom area is in the Back of Trailer I can probably find a way to tie it in there or I may just go where the sink is.
Ruben Zamora
Old 07-19-2011, 10:04 AM   #7
We have the outdoor shower option on our TT... Looks like they just tapped into the low point drain lines. As my shower is mounted on the side towards the rear of the camper, and below that coming out the bottom are the hot and cold drain lines. Drain lines are just a red and blue hoses with caps on the end. Guess valves would have blown the budget.
2005 Ford Excursion V10 4x4 4.30's
2011 Salem 26TBUD
brianb is offline   Reply With Quote
Old 07-19-2011, 10:45 AM   #8
leencharlotte's Avatar
I have had my trailer for a few months and I just noticed I have a cold and hot (red and blue with seal plugs not valves) water connections under my trailer which I assume are for a shower connection??? I have an enclosed underbelly and they pipes sit b/w the skirt and underbelly. I didn't order the outdoor shower but it came plumbed for it. If may want ti check and see if you already have connections
And on a side note, I can only find one drain underneath and that is for my fresh water tank. Do some trailer not have them?
leencharlotte is offline   Reply With Quote
Old 07-19-2011, 10:51 AM   #9
RubenZ's Avatar
Hmm, maybe thats what mine are. They are the same colors as yours and are b/w skirt and underbelly. Thats what sucks about having trailer in storage, i wont be able to check until we go camping this weekend.
Ruben Zamora
Old 07-19-2011, 10:55 AM   #10
Moderator
Leencharlotte,
You stated in post #8, "I have a cold and hot (red and blue with seal plugs not valves) water connections under my trailer which I assume are for a shower connection???"
Bad assumption. These are your low point drains. Yes they have pressure when the trailer has pressure, that is why they are capped. The other drain you have found is for the fresh water tank. Outside showers should be mounted in the wall, and plumbed inside. Otherwise, if you camp in freezing temps, all that exposed plumbing may freeze. I just put one in a Wildwood for someone. Make sure you find the studs, and don't cut through one when picking a location. Once you cut a hole in the side of the camper, you are pretty much committed.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
» Online Users: 535
92 members and 443 guests
12vdzl, 4bnabird, 4runner freak, 8261ss, abjb, backpacker3, Barney1, Bearcat55, bikendan, Bob z, bouldercamper, bozemancamper, brania, buzzmonster, campfun, CampinQueen, Canuck_Doug, carsonizik3, Cascade Bob, chiro, ClampNfish, cmptrkd, cousin01, Cowracer, cstover, dashonthedash, daveinpickerington, daw592, depo, djorgensen3, dlmurray51, DonCath25ds, donh, donn, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, iluvlcy, JJFerg, JLcampgirl, Joseph5410, kgmat, KKapa, Lonewolfcry, ltypd, Mad4sax, mcdiver, Mkayers, Mpwelch50, mtnguy, NeilM108, onetonford, Pa-cj5, Pinesman, Poppy Bill, PrairieBoy, punkaccountant, rbrandon, rglickman, RichN, Riva, Roamin Ovum, rschroe, Rugged Brown, Russ, Scriggs1, Sparkbark, SpringerPop, tfennell81, TheSasks, Titleguy, Tom993, tonybab, troyt, UPGRADER, VTX Al, wbdvt, wfmdfm, Whiskeyjack, Whiteknight, whj77372, wvfireboss
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
