Old 08-15-2014, 07:37 AM   #11
I would have to verify this but I believe the reason for the low pressure is a watter saving disc in the shower head. If you enlagre the hole in the disc the pressur should increase.
harderd is offline   Reply With Quote
Old 08-15-2014, 07:49 AM   #12
If you enlarge the holes you will get (Less) pressure but more (Volume)! Youroo!!
Old 08-15-2014, 08:06 AM   #13
I took the disk completely out. Now get enough water to do some good.
2013 Flagstaff 27RLWS
2014 Ford F150 Ecoboost
30 nights in 2015 so far
roanmountaincampers is offline   Reply With Quote
Old 08-15-2014, 08:31 AM   #14
vinmaker's Avatar
I am not a fan of the low pressure either. Almost seems like a joke to me.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-15-2014, 11:13 AM   #15
You are correct. I choose my wording incorrectly. I do wonder however, if the shower heads actually reduce pressur b/c my new home shower head had no pressure or volume untill I removed the reducer which had a spring behind it. I now get great volume with pressure.
Old 10-01-2014, 08:39 AM   #16
Old Ram Guy
Avenger61's Avatar
If it's just more pressure you are looking for, I always put a spot of super glue on about a third to half the holes on the factory installed sprayer on the outside shower. This increases the pressure significantly.
Marty, Jenice and DD
Avenger61 is offline   Reply With Quote
door, show, shower, modifications
