Old 04-14-2013, 05:40 PM   #1
pwrboatfan's Avatar
Outdoor Speakers
I am going to replace my outdoor speakers that are blown and shot. I know they are 5.25 in size but does anyone know the maximum depth of the speaker that can be used? I thought maybe someone has already replaced their factory speakers. I am looking to upgrade to a better quality speaker, but want to make sure they will fit. Since the old ones are caulked in, I cannot simply remove them to see how much space I have.
2006 Salem 392FKTB PT
Seasonal Camping at Pomme De Terre Lake in MO
pwrboatfan is offline   Reply With Quote
Old 04-14-2013, 06:57 PM   #2
wneise's Avatar
Unfortunately, that may be the only way to be 100% sure. If there are cabinets on the inside behind the speakers, you can check to see how much the factory units intrude beyond the wall. The wall itself should be cut all the way through since speakers are thicker than most rv exterior walls. The easiest thing to do is to research what u have, usually a cheap marine speaker and find the dimensions on that.
wneise is offline   Reply With Quote
Old 04-15-2013, 09:52 AM   #3
great white's Avatar
Are they in "pods" or are they mostly tight to the exterior wall?
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 04-15-2013, 08:11 PM   #4
pwrboatfan's Avatar
Tight to the exterior walls.
Old 04-15-2013, 08:35 PM   #5
wfmdfm's Avatar
This is the front and rear view of the speakers I removed from the outside wall. I replaced with surface mount. There was a hole in the side but only had the cable coming thru it.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 04-15-2013, 08:39 PM   #6
GASPEDDLER's Avatar
Upgraded my outside speakers this weekend
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 04-15-2013, 09:04 PM   #7
pwrboatfan's Avatar
Thanks...that was what I was looking for. I looked up the specs and the mounting depth is 2.375 inches on your speakers. So now I have idea how deep of a speaker I can use.
