Old 08-16-2013, 04:51 PM   #11
cmptrkd's Avatar
Chof16, I hope I can help some.
There is a website called monorpice.com They are great for buying many things audio/video/technology related. If I am understanding you right, you're looking for a mount to keep on the outside of the TT and then be able to simply drop the tv onto, and lift off when done. This is what's on some of the new TT out there. They usually expect you to do this with about a 19" tv. When I was searching monprice for you, I found that they do have a smaller bracket that holds up to a 23" and then I found one that will support up to a 32". This is the link to the one that is 32" and you can search the site and find the smaller one if that is what you are looking for.
HDMI Cable, Home Theater Accessories, HDMI Products, Cables, Adapters, Video/Audio Switch, Networking, USB, Firewire, Printer Toner, and more!
A decent stud finder should help you, but you can also do some pin holes as well. With the weight of a newer style LED 32", if you can hit a stud on one side and get two screws into it, I would feel plenty confident. Remember, you're not running the trailer up and down the bumpy roads with this TV hanging on here. We have a 32" LCD in our bedroom of our Sierra 365saq and I only could hit one stud. It's been up for a year with no problems.
If you cannot hit a stud, I am sure a backerboard will be just fine.
Good luck, post pictures after!
Loving our Sierra 365SAQ
Nights camped so far in 2016 = 0
Although Many trips scheduled.
cmptrkd is offline   Reply With Quote
Old 08-16-2013, 11:30 PM   #12
GASPEDDLER's Avatar
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 08-18-2013, 08:25 AM   #13
Thanks for the responses and good information. The low profile mount is what I was looking for. The biggest thing I am worried about is finding a stud and drilling/screwing into the exterior fiberglass wall. That is why I was thinking about trying to find a stud from the inside. I have read on several threads here that stud finders wont work- any experience that they do?
2011 Surveyor SP260
2012 Ford Expedition
chof16 is offline   Reply With Quote
Old 08-18-2013, 11:23 AM   #14
Adony's Avatar
Screwing in the mount...
Originally Posted by GASPEDDLER View Post
When screwing a mount like this into a stud behind the aluminum siding, did the mount draw the siding in when snugging in the screws? My siding seems to push in a little when pressure is applied.. Hope you can understand what I mean.. This is exactly what I want to do as far a a mount is concerned..
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 08-18-2013, 02:16 PM   #15
GASPEDDLER's Avatar
No, the siding is not drawn in. You might try some sort of spacer behind the mount in the siding valley.
Equalizer E2 Hitch
door
