Old 08-16-2013, 07:52 AM   #1
Outdoor TV
I would like to add an outdoor TV to our 2011 Surveyor SP260. I did a quick search of the forums and didn't see a whole lot of info. One good thread on a mounted rail and fabricated bracket. Since fabrication is not really in my wheelhouse I am hoping to find a small off the shelf low profile bracket similar to what comes on some of the newer trailers. I think the easiest is just to mount a bracket to the wall below the dinette window. Given the location I could likely put a backer board inside the trailer for support if needed, and it would be hidden by the dinette cushions. Any tips on a good bracket, drilling through the wall (yikes), the need for a backer board, screws vs through bolts, etc? I know it may be pretty difficult to find a wall stud so I may try some test "pinholes" on the inside. Also I assume I need to start small and progress to larger bits to not crack the fiberglass. Thanks in advance for any tips and ideas.
2011 Surveyor SP260
2012 Ford Expedition
chof16 is offline   Reply With Quote
Old 08-16-2013, 08:14 AM   #2
TURBS's Avatar
Do you have a cubby to spare?
Old 08-16-2013, 08:15 AM   #3
TURBS's Avatar
Old 08-16-2013, 08:55 AM   #4
Unfortunately no cubbies-only the front storage area. I was originally thinking about putting an articulating arm in the front pass through storage area but I don't think I could get it to reach under the awning.
2011 Surveyor SP260
Old 08-16-2013, 09:29 AM   #5
Phat Phrog Phlunky
essness's Avatar
I ordered this from their ebay store.
Home
My garage tv is a 32" lcd that weighs 12 pounds without the base. This bracket is rated for 27 lbs.
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
essness is offline   Reply With Quote
Old 08-16-2013, 09:48 AM   #6
CRZ
CRZ's Avatar
Hey 100turbo, did you buy that mount or did it come with the trailer? That's the kind of mount I was looking for. If you bought it do you have a link?
CRZ is offline   Reply With Quote
Old 08-16-2013, 10:00 AM   #7
TURBS's Avatar
Unfortunately The mount came with the trailer.
Check moryde.
http://www.morryde.com/aftermarket/tv-mounts.html
Old 08-16-2013, 10:21 AM   #8
CRZ
CRZ's Avatar
Check moryde.
Thanks!
Old 08-16-2013, 02:12 PM   #9
Camper Less Camping
Cajun Po-Boy's Avatar
If I didn't have so much gear in my basement, this TV bracket would work great....thinking /
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-16-2013, 02:14 PM   #10
TURBS's Avatar
Sorry lol!
Mor/ryde has a lot of different options!
door
