Old 10-18-2016, 07:04 PM   #1
Outside grill
Has anyone converted the supplied outside grill that quick connects to the campers propane system to a stand alone bottle? If so what is involved?
Kenroo84 is offline   Reply With Quote
Old 10-18-2016, 07:06 PM   #2
SeaDog's Avatar
Your connection at the camper is low pressure an stand bottle will provide high pressure you will need to add a regulator if you want to use the grill with a bottle.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-18-2016, 07:32 PM   #3
davel1971's Avatar
probably can use a replacement hose with regulator for gas grill. Fittings are pretty standard.
David & Lynn
Old 10-18-2016, 07:34 PM   #4
Nurek's Avatar
I thought the OEM grill was the biggest disappointment I've ever experienced in a grill and after the first use put it back in the bag and tucked it away to never use again.
This model \/
So what I did was buy a CampChef Explorer 160 2 burner stove and the Grill Box 30 14" where it actually gets sear marks on your steak and cooks it properly. It uses infrared heat to cook, not flames.
That OEM grill was garbage IMO.
All this can be run by a stand alone bottle or if you want like I did, ditch the stove hose (which had a regulator) and do a mod to tie into the trailer supply, where you don't need to get a regulator.
2011 Nissan Xterra
2016 Rockwood MiniLite 2306 First ever RV.
Nights Camped 2016 [24]
Nights Camped 2017 [tbd]
Nurek is offline   Reply With Quote
