Old 08-25-2013, 01:39 PM   #1
PHS79's Avatar
Outside spray hose
Our 2012 Grey Wolf 26BH does not have an outdoor shower or any way to get water from the outside of the camper (other than the low point drains). So after seeing the outside spray hose on my cousins 2012 Dutchman Kodiak I am brain storming ways to create one. I am looking for cold water only, we will probably only use it for getting the dogs water and hosing our DD off before she tracks sand and such into the camper like she does now.
Has anyone ever done anything like this?
My idea is to hook up to the pressurized side of the low point drains, take the valve off and up a T in then move the valve to the bottom of the T. Then off the side of the T run a water line out to what ever point we decide is best, at the end of the water line put on a female air hose coupler so I can disconnect the hose. For the hose I was thinking of using a self coiling air hose with the appropriate fittings so I can put a standard spray nozzle on.
Any input would be great!
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 08-25-2013, 04:05 PM   #2
Twisty's Avatar
That idea will work well.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 08-25-2013, 05:30 PM   #3
Paul & Sheri
pwb01's Avatar
If you have Pex tubing it's a simple matter of cutting in a Shark Bite tee. With a standard reducer (at Home Depot for example) tie in a standard $15 sink sprayer. I did this with a sprayer behind the toilet for cleaning and the whole process took less than 30 minutes. I mount it on a standard shower head holder.
Maybe you can find a location near any cold water line and mount it in a box installed on the exterior. I've seen boxes with doors for power wires for example on PPL RV parts site. The rest is Home Depot.
For that matter, the regular exterior showers with head, valves and box aren't very expensive if you have a place to put it.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 08-25-2013, 09:06 PM   #4
Fire Instructor's Avatar
Anywhere you have H&C plumbing running reasonably close to an outside wall, installing an outside shower should be relatively easy. The plumbing fittings are VERY inexpensive if you avoid the overpriced "sharkbite" fittings, and you can rent the crimp tool necessary from Home Depot or Lowe's (or even PURCHASE it outright, for the cost of a few sharkbite fittings!
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
Fire Instructor is offline   Reply With Quote
Old 08-25-2013, 09:47 PM   #5
PHS79's Avatar
Thanks for the input, I looked once at maybe putting a full outside shower in but I couldn't find a good spot to place it that would work well for the water lines. I have a good buddy who is a master plumber, maybe I will have him come over and see what he thinks.
nights camped:
Old 08-26-2013, 05:19 PM   #6
A self-coiling water hose with a nozzle can be purchased at Target for less than $20. It is likely cheaper than the air hose and fittings.
Grim is offline   Reply With Quote
Old 08-26-2013, 08:21 PM   #7
PHS79's Avatar
I have the air hose and hopefully about 90% of the fittings in my garage just collecting dust. That is the reason I was thing going that route, I might as well put the stuff to use.
nights camped:
Old 08-27-2013, 05:25 AM   #8
RPAspey's Avatar
air line fittings and stuff will rust, if you go that route.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 08-27-2013, 09:14 PM   #9
PHS79's Avatar
I had thought of that, all the fittings are brass or stainless including the "air" fittings that I am going to use. Since is so damn hot here this week I won't have it done before we leave for the weekend, but I am planning on working on it as soon as I can find the time. I will post some pics when I get it done.
nights camped:
Old 08-27-2013, 09:24 PM   #10
RPAspey's Avatar
good! I've never seen SS fittings. Lucky you! I've been thinking of the same mod, but it's low on the "list"
Old 08-27-2013, 09:45 PM   #11
daydreaming about camping
jeeplj8's Avatar
I have to say you might be happier with this route. Or trailer came with am outside shower. Bit we still carry one of these. I run it off a wye fitting at the campground water source for full pursue high flow water. Great for hosing off kids, dogs etc.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 08-28-2013, 09:50 AM   #12
PHS79's Avatar
If we are at a CG that has water to the site then I hook in a T and run 2 hoses, one for the camper and.the other for spraying off. But of the 17 or so nights that we have be camping this year only 5 we have had water to the site, all the others are at county CGs where you have to fill up the tank before we go.
The whole reason I am doing this is to try and keep as much sand out of the camper as possible since my 4 y.o. DD usually finds a way to be covered from neck down.
As for the SS fittings, I have a good buddy who is a master plumber and owns his own company, I got the fittings from him. I don't know what they were actually from or why he had them, but they will work great for me, hopefully...
nights camped:
Old 08-31-2013, 02:00 PM   #13
golfmedik's Avatar
Please get us some pics. I just bought an '08 Vortex toy hauler for deer camp, and would love to have a sprayer like that. I have one on the Sandpiper and want one on the Vortex. Now that you've explained what you were doing. doesn't seem all that difficult! I hope I'm right!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
