Old 06-19-2015, 02:09 PM   #1
Cool Outside Wall Antenna Mount
I want to mount an outside CB antenna to one (vertical) side of my 2015 C-class Prism RV.
As this will require drilling holes in an outside side-wall (and also inside paneling likely), I'd like to know what the inside-outside wall cross-section looks like e.g. is there a void between interior paneling and and outside Azdel composite sidewalls?, and also the void's dimension? I think my coach uses aluminum framing.
I'm not getting reliable readings on my stud finder. I'm looking for a driver's side mounting location near the 'cab-over' bunk area just aft of the little cab-over window.
Can anyone help
2015 Coachmen Prism 2150LE
MBenz Sprinter Chassis
Dennise is offline   Reply With Quote
Old 07-30-2015, 10:23 PM   #2
If your mirrors hVe a flat surface on top of its arm you can use hose clamps to attach a Freightliner Casita antenna mount. Then you can mount a no ground plane Firestik antenna and run the coax in behind the door hinges and into the bottom of the door. Works well with no holes drilled and look nice.
AbdRahim is offline   Reply With Quote
Old 07-31-2015, 07:54 AM   #3
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
On a Class c, great idea is to attach antenna to top of rear ladder and run coax down and along the frame, than back up into the firewall.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 08-01-2015, 05:42 PM   #4
Thanks all for your suggestions.
I decided to mount a 4 ft. Non Ground Plane Firestik side mount antenna just forward of the little (driver's side) window on my over-cab bunk.
I had to drill a hole through my side-wall and remove enough 'Styrofoam' from the inside wall to secure the mount and access to the coax cable connector. I used an (intentionally) broken off sabre-saw blade for the inside panel and Styrofoam cut-out (about 2" X 4" X 1 7/8" deep).
Preliminary checks show all is well so far, but haven't really tested it on the road.
antenna, mount
