07-09-2011, 01:21 PM
Originally Posted by frankm
I had the same idea but I went way simpler than you. Here is my creation:
Attachment 6699
Frank, That's exactly what I'd like to do. Where did you get the longer bracket for the back edge of your shelf/table?
07-13-2011, 03:23 PM
Originally Posted by yvesm
I don't use the grill that came with my camper so I made a lightweight work table that hangs on the rail and folds up for storage when not in use. I made it from 1/2'' MDO plywood which is a lightweight exterior plywood. This table works great for my Coleman stove. I also mode the table to fit a 2 burner Atwood drop in cook-top, so when I see one on E-bay for a good price I will use that instead of the Coleman stove. The table has 1 coat of exterior primer and 2 coats of exterior paint
Looks great! I'm wanting to build a similar table for ours (but a simpler version  ). Our previous Flagstaff came with a small table, but our new fiver did not. Where did you get the rail to attach to your table that hooks into the rail on the camper?
Thanks for the help!
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
Nights Camped 2012: 2
07-14-2011, 09:07 AM
My TT came with a smaller 12" x 12" work table for hanging outside. I removed its rail, cut it in half and installed both pieces 18" apart on the new 36" x 12" table. I used two shelf brackets w/4" hinges (for folding when not in use and in storage compartment) for support and at the point where the wooden brackets make contact with the TT wall I installed nylon nail on table glides (see pic below)
Frank & Rita M
2008 Ford FX2 F-150 3.73 CC 139" WB w/EQ4 WDS
2011 Rockwood 2702SS
07-14-2011, 10:24 AM
Nice job. Do the leg supports fold for storage?
07-17-2011, 08:55 PM
07-18-2011, 08:41 PM
Table weights about 20 lbs, rail is about 35'' wide and seems to be well attached. If it looks like it will come loose I will screw thru the side wall and use nuts on the inside. The rail is opposite where my dinnete bench is so the nut will be bellow the seating area and hidden
Anyone know what the maximum weight the bracket can support? I purchased a new bbq that it is 20+lbs.
WestCoastRV'er
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
07-19-2011, 07:24 PM
Great idea. I wonder if I can mount the rail myself and add my own? Something like that might void a warranty...
07-19-2011, 08:18 PM
That should not void your warranty. Just make sure you seal around it very well after you mount it.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 539 |
| 93 members and 446 guests |
| 12vdzl, 4bnabird, 4runner freak, 8261ss, abjb, backpacker3, Barney1, Bearcat55, bikendan, Bob z, bob7794, bouldercamper, bozemancamper, brania, buzzmonster, campfun, CampinQueen, Canuck_Doug, carsonizik3, Cascade Bob, chiro, ClampNfish, cmptrkd, cousin01, Cowracer, cstover, dashonthedash, daveinpickerington, daw592, depo, djorgensen3, dlmurray51, DonCath25ds, donh, donn, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, iluvlcy, JJFerg, JLcampgirl, Joseph5410, kgmat, KKapa, Lonewolfcry, ltypd, Mad4sax, mcdiver, Mkayers, Mpwelch50, mtnguy, NeilM108, onetonford, Pa-cj5, Pinesman, Poppy Bill, PrairieBoy, punkaccountant, rbrandon, rglickman, RichN, Riva, Roamin Ovum, rschroe, Rugged Brown, Russ, Scriggs1, Sparkbark, SpringerPop, tfennell81, TheSasks, Titleguy, Tom993, tonybab, troyt, UPGRADER, VTX Al, wbdvt, wfmdfm, Whiskeyjack, Whiteknight, whj77372, wvfireboss |
| Most users ever online was 1,025, Today at 01:04 PM. |
