Old 07-04-2011, 12:21 PM   #1
yvesm's Avatar
Outside work table that folds up
I don't use the grill that came with my camper so I made a lightweight work table that hangs on the rail and folds up for storage when not in use. I made it from 1/2'' MDO plywood which is a lightweight exterior plywood. This table works great for my Coleman stove. I also mode the table to fit a 2 burner Atwood drop in cook-top, so when I see one on E-bay for a good price I will use that instead of the Coleman stove. The table has 1 coat of exterior primer and 2 coats of exterior paint
ID:	6654   Click image for larger version
ID:	6655   Click image for larger version
ID:	6656   Click image for larger version
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 07-06-2011, 12:14 AM   #2
Did you have to reinforce the bracket? That is a very nice table you made.
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 07-06-2011, 06:18 AM   #3
yvesm's Avatar
Table weights about 20 lbs, rail is about 35'' wide and seems to be well attached. If it looks like it will come loose I will screw thru the side wall and use nuts on the inside. The rail is opposite where my dinnete bench is so the nut will be bellow the seating area and hidden
Old 07-06-2011, 06:23 AM   #4
Old car's Avatar
Nicely done. It's giving me some ideas since I don't use the grill either.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 07-06-2011, 07:37 AM   #5
Very nice! I would think there would be a market for something like that.
Don and Laura + Roo
Chesapeake, VA
VAlover is offline   Reply With Quote
Old 07-06-2011, 07:43 AM   #6
Rugged Brown's Avatar
Neat job, but looks heavy.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 07-06-2011, 08:05 AM   #7
frankm's Avatar
I had the same idea but I went way simpler than you. Here is my creation:
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 07-06-2011, 08:50 AM   #8
yvesm's Avatar
Attachment 6699
That was my first go around, but I will be cooking on this table and I wanted some protection from wind and I wanted to also protect the camper wall. The table is designed to accept an Atwood 2 burner drop-in cook top. I still however like the simple approach, but has an engineer we like to over design things
Old 07-09-2011, 12:10 PM   #9
Does anyone know if those slide rails are available somewhere? I guess I can search. That gives me some ideas.
hntz4x4 is offline   Reply With Quote
Old 07-09-2011, 01:02 PM   #10
yvesm's Avatar
You might try Forest River Parts, or Camping World might have them Camco Mfg Inc - RV Grill Mounting Rail - Grill Accessories - Camping World
Old 07-09-2011, 01:21 PM   #11
Attachment 6699
Frank, That's exactly what I'd like to do. Where did you get the longer bracket for the back edge of your shelf/table?
dlhoppe is offline   Reply With Quote
Old 07-13-2011, 03:23 PM   #12
Looks great! I'm wanting to build a similar table for ours (but a simpler version ). Our previous Flagstaff came with a small table, but our new fiver did not. Where did you get the rail to attach to your table that hooks into the rail on the camper?
Thanks for the help!
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
fordmantpw is offline   Reply With Quote
Old 07-14-2011, 09:07 AM   #13
frankm's Avatar
My TT came with a smaller 12" x 12" work table for hanging outside. I removed its rail, cut it in half and installed both pieces 18" apart on the new 36" x 12" table. I used two shelf brackets w/4" hinges (for folding when not in use and in storage compartment) for support and at the point where the wooden brackets make contact with the TT wall I installed nylon nail on table glides (see pic below)
Frank & Rita M
Old 07-14-2011, 10:24 AM   #14
jerry929's Avatar
Nice job. Do the leg supports fold for storage?
jerry929 is offline   Reply With Quote
Old 07-17-2011, 08:55 PM   #15
OK, I think I have found the rails online:
Patrick Table Support - Supports & Brackets - Table - Hardware
Amazon.com: Patrick Metals 164922 30" Table Support Sliding: Automotive
Old 07-18-2011, 08:41 PM   #16
WestCoastRV'er's Avatar
Anyone know what the maximum weight the bracket can support? I purchased a new bbq that it is 20+lbs.
ID:	6878   Click image for larger version
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 07-19-2011, 07:24 PM   #17
Hidaho's Avatar
Great idea. I wonder if I can mount the rail myself and add my own? Something like that might void a warranty...
Hidaho is offline   Reply With Quote
Old 07-19-2011, 08:18 PM   #18
That should not void your warranty. Just make sure you seal around it very well after you mount it.
