Old 04-01-2015, 07:11 AM   #21
camper1999's Avatar
As others have said well worth the money. Even when dry camping it uses less water but the pressure is great.
2011 GMC 2500HD Diesel
Old 04-01-2015, 07:12 AM   #22
bsmall's Avatar
No Brainer,,,,,in my book, buy it, you'll love it..
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 04-01-2015, 07:21 AM   #23
This product is so good that we replaced the shower heads (Moen $$) in our home with these (Oxgenic Heads)! Youroo!!
Old 04-01-2015, 08:41 PM   #24
Agreed. One of the easiest mods there is and one with lots of benefit for little cost.
jrwalkerpa1 is offline   Reply With Quote
Old 04-01-2015, 09:09 PM   #25
nuisance's Avatar
The first year we owned our TT we used the standard shower head. The second year we switched to the Oxygenic Head and I am sorry that I didn't change out the first year. Well worth the money. Less water coming out of the shower head means less going into the grey tank which means not emptying as often. Or refilling the fresh tank.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 04-02-2015, 07:17 AM   #26
dcheatwood's Avatar
Its like pinching the end of a water hose to spray harder/farther. More pressure, less water and yes, a little noise. But its the best $27 I spent on upgrade.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 04-02-2015, 10:05 AM   #27
BamaBob's Avatar
Originally Posted by CSMRetired View Post
I think they are all plastic, white or otherwise
ours is brushed nickel.....but very light
X2 what CSM said - ours is brushed nickel (if you go on Amazon, they have several colors to choose from).
When you install it, get a cut off valve to go in-line with the shower head hose (for those times when water conservation is a must).
Also, before installation, check all the hose fittings and REVOVE any flow limiters.
Use this fine gadget to regulate the water pressure to your rig:
Amazon.com: Valterra A01-1117VP Brass Lead-Free Adjustable Water Regulator: Automotive
And you will have a shower darn close to the one you have at home (assuming you a re not a full timer, because then you ARE at home )
Note: Most RV Manufacturers recommend 45-50PSI a lot of folks run at 55PSI, and the folks at RV-Dreams (a GREAT reference site BTW) say that "Modern" RVs can run at 60-65PSI.
We keep ours set at 55PSI and our camper shower has the same pressure as our shower at home. (Assuming the CG water pressure is>=55 PSI)
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-09-2015, 09:39 AM   #28
Gregg Willow's Avatar
Ditto!
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
Old 04-09-2015, 11:02 AM   #29
Just installed mine.....love it. Wish I would have done it sooner.
Armadabjj is offline   Reply With Quote
Old 04-09-2015, 11:05 AM   #30
Love My Sunseeker
DXSMac's Avatar
Such a huge difference that when I trade RV's, I take the Oxygenic with me and put the old one back on the traded one.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
show, shower
