Old 04-09-2015, 08:48 PM   #31
As others have send,it's worth doing...we do a lot of "dry" camping and besides the added pressure having the shut off is great!
Truck 2009 GMC 2500 HD,D/A,Ext.Cab,SB,air bags, lift kit, flow gate, etc.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
Camping Day's: 2012:25,2013:27,2014:38,2015:38
Little John is offline   Reply With Quote
Old 04-09-2015, 08:57 PM   #32
cstover's Avatar
Can't tell you.....I have never used the original. Always replaced prior to first use with an Oxygenics.
cstover is offline   Reply With Quote
Old 04-09-2015, 09:25 PM   #33
Phat Phrog Stunt Crew
elind's Avatar
Originally Posted by HSVBamaBob View Post
X2 what CSM said - ours is brushed nickel (if you go on Amazon, they have several colors to choose from).
When you install it, get a cut off valve to go in-line with the shower head hose (for those times when water conservation is a must).
Also, before installation, check all the hose fittings and REVOVE any flow limiters
Use this fine gadget to regulate the water pressure to your rig:
Amazon.com: Valterra A01-1117VP Brass Lead-Free Adjustable Water Regulator: Automotive
And you will have a shower darn close to the one you have at home (assuming you a re not a full timer, because then you ARE at home )
Note: Most RV Manufacturers recommend 45-50PSI a lot of folks run at 55PSI, and the folks at RV-Dreams (a GREAT reference site BTW) say that "Modern" RVs can run at 60-65PSI.
We keep ours set at 55PSI and our camper shower has the same pressure as our shower at home. (Assuming the CG water pressure is>=55 PSI)
Bob, Didn't your Oxygenic not come with an inline valve? Mine did. Also why to try to take off any flow limiters? Isn't it the idea to save water with the 2 gpm shower head instead of a whimpy 3 gpm head. Mine is great the way it came out of the box.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 04-10-2015, 08:58 AM   #34
iowaborn's Avatar
Send a message via AIM to iowaborn
Replaced the shower head with the Oxygenic because of the rave reviws on the forum. I must say I am disappointed, the water flow does not shut off completely with the inline shut off valve. Anybody else experienced this? We like to shut it off using the inline valve, lather up, then turn it back on to rinse off.
2013 F-250 CrewCab 6.7 PowerStroke 4X4
2017 Silverback 33RK
iowaborn is offline   Reply With Quote
Old 04-10-2015, 09:25 AM   #35
Iowa Born, This shutoff valve from Ace HW works VERY well when the head is in the wall Holder or in Your Hand! I find the type where the S/O valve is IN the handle a PITA to turn off when your Hands are (Wet and Soapy)! As well the Optional S/O valve does NOT shut off 100%. We take ALL our showers in the unit,going on 5 years use! Youroo!!
Old 04-10-2015, 09:42 AM   #36
dj3spots's Avatar
Of all the things I've gotten for our trailer, and there have been many, this is the only thing DH has not declared as a waste of money. You want one of these, you really do.
dj3spots is offline   Reply With Quote
Old 04-10-2015, 09:43 AM   #37
elind's Avatar
I thought the reason for the slow leaking valve was to keep the water temp constant during use. My old one I had would have a blast of hot water when I would restart it.
2014 Wildcat 327ck
Old 04-10-2015, 09:45 AM   #38
mTn_biKer65's Avatar
We love ours, unfortunately it didn't come with the shut-off valve so we had to add that after the fact. If you do plan to go ahead make sure your model comes with the shut-off included.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 04-10-2015, 09:48 AM   #39
Loved there one we had on the rig we traded in. The new rig has a bronze color. May have to bite the bullet and get the white or chrome. I have not seen a bronze.
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 04-10-2015, 09:54 AM   #40
Could,depends on how your unit is Plumbed. If you Sing in the Shower,sing a Shorter Song! Thus less time for the Hot Shot of Water! We have been happy for (5) years of shower with S/O use. Youroo!!
show, shower
