05-31-2011, 05:35 PM
Oxygenics Shower Heads...
.... So, received and installed our new Oxygenics Shower Head today and discovered that the system does not include a "shut-off" valve. Perusing the Oxygenics website, I discovered that they discourage the use of shut-off valves noting that it is a safety issue to prevent burns from hot water. That gets me to wondering if others who are already using the Oxygenics showers have had a problem in this regard. After all,if one of the main reasons for switching to Oxygenics is to save water, not being able to take a "Navy" shower seems to defeat that purpose. Does the little "control" knob reduce the flow enough to save water and still provide a decent shower ?
...VTX-AL
05-31-2011, 05:44 PM
I added a shut off valve on the hose where it connects to the faucet - $4 at Home Depot.
I rarley use the shut off - I just turn the knob to where it minimal spurts water until I am ready to rinse - never had an issue with the water being too hot from shutting it off either
I love the shower head and glad I upgraded - the stock unit was junk - well worth investment IMO
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
05-31-2011, 06:09 PM
Moderators' Assistant
we use the knurled knob on the shower head's handle and feel it does a good enough job not to have install a separate shutoff valve.
it reduces the flow to a trickle which is fine.
if you'd read some of the Oxygenics posts, it's mentioned many times that it doesn't have a full shutoff feature.
06-01-2011, 02:24 PM
we also use the $4.00 fix and never turn the faucets off
actually i bought it for our 09 holiday rambler and removed it when trading in
we almost had that motorhome where everything was done where getting there on our gtowne so i better keep the wifey away from the charlestons
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2011wrangler mangotango toad
take us
06-01-2011, 05:19 PM
Not having a shut valve is a "Feature." There is a trickle of water flowing that lets you keep wetting the soap as you go along. But the best thing is: when you turn the water back on to operating flow it is at the correct temperature. I really hated the original shower head that came with the trailer. When you turned it back on it was always cold. Most of the places I was using the TT it was freezing cold. I wouldn't waste the time or money installing a separate shut off valve.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
06-01-2011, 06:09 PM
I installed a small ball valve on mine and have no problems with it.When I'm dry camping I want to save as much water as I can.
2009 Chevy 2500HD Crew cab 4x4
2008 Wildcat 29RLBS
06-03-2011, 07:33 PM
Glad to here that all of you like this shower head.  I'm wanting to upgrade. I recently traded a TT that had a 6 gallon dsi/electric Dometic water heater, for out new Rockwood that has a 6 gallon dsi/electric Suburban water heater, and the Suburban's 6 gallons doesn't last as long as the Dometics. I've checked that electric and gas are working at the same time, so it must me the flow and I think this could be the fix needed to finish the shower without getting the last cold blast.
06-03-2011, 07:41 PM
Lou Amadio
Times two. Even though it has a lifetime warranty, the twist valve broke the first trip out. Rather than mail it away, I just replaced it with a small ball valve as well.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
06-03-2011, 08:26 PM
Originally Posted by VTX Al
.. Does the little "control" knob reduce the flow enough to save water and still provide a decent shower ?
...VTX-AL
nope... the comfort valve on the Oxygenics shower head will shut the water flow down to a trickle, but will not shut off the water flow completely. This shower head was a great upgrade..! But how much difference will a trickle matter anyway if its only a few seconds between "rinse and repeat"...?
06-03-2011, 09:12 PM
Lou Amadio
The idea of a trickle instead if a shutoff had to do with temp control.
Keeping the water flowing maintains temp without using too much water.
If you use the shutoff, the water in the hose gets cold.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 542 |
| 91 members and 451 guests |
| 12vdzl, 4bnabird, 4runner freak, 8261ss, abjb, backpacker3, Barney1, Bearcat55, bikendan, bob7794, bouldercamper, bozemancamper, brania, buzzmonster, campfun, CampinQueen, Canuck_Doug, carsonizik3, chiro, ClampNfish, cmptrkd, cousin01, Cowracer, cstover, dashonthedash, daveinpickerington, daw592, depo, djorgensen3, dlmurray51, DonCath25ds, donh, donn, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, JJFerg, JLcampgirl, Joseph5410, kgmat, KKapa, Lonewolfcry, ltypd, Mad4sax, mcdiver, Mkayers, Mpwelch50, mtnguy, NeilM108, onetonford, Pa-cj5, Pinesman, Poppy Bill, PrairieBoy, punkaccountant, rbrandon, rglickman, RichN, Riva, Roamin Ovum, rschroe, Rugged Brown, Russ, Scriggs1, seatosea, Sparkbark, SpringerPop, tfennell81, TheSasks, Titleguy, Tom993, tonybab, troyt, UPGRADER, VTX Al, wbdvt, wfmdfm, Whiskeyjack, Whiteknight, whj77372, wvfireboss |
| Most users ever online was 1,025, Today at 01:04 PM. |
