Old 08-30-2016, 06:00 AM   #11
waiter21's Avatar
I climbed up on the roof and painted the exterior of the bubble with a regular can of Rustolium.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-30-2016, 07:55 AM   #12
Wolverine 1945's Avatar
I used Restoleum Ultra,,, made for Wood / Metal & Plastic,,, not sure I would recommend it,,, it took 5 coats over 5 days ??? I did not want to see brush marks from inside !!! It was the only reasonable priced paint I saw in a Quart can !!!
Wolverine 1945 is offline   Reply With Quote
Old 09-01-2016, 01:20 PM   #13
I left mine clear. Took off the inside section and foiled it, added some 1" foam and them foil on inside. Reinstalled and the inside of the bathroom stays as cool as the rest of the RV. I also had all of the windows limo tinted and painted the front door frost window black. Rv stays cooler now by 10 degrees. I am in Texas, so we are used to 100+ degree temps. This works great.
Kstedman is offline   Reply With Quote
Old 09-02-2016, 07:43 AM   #14
I am hoping that the paint will help protect the plastic,,, Smoked vent cover for Bath fan was COOKED after just 3 years !!!
Old 09-02-2016, 07:55 AM   #15
Originally Posted by fella10 View Post
DW and I have major disagreements about that skylight, and a constant battle over the Reflectix piece that I stick up inside to block the sun, it disappears all the time,... she wants the light, is cold natured and welcomes the heat it lets in,.....I want to block the heat from coming in to help the ac and "Don't need to see out that one anyway",...... two overhead lights in the bathroom is enough light for anybody,..... she doesn't know I painted over the dome, but will tomorrow when we get to the cg and she removes the Reflectix shield to hide it,....... happy trailering.........
So, how did your trip work out? Is she talking to you yet?
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
CampingGator is online now   Reply With Quote
Old 09-02-2016, 08:18 AM   #16
Originally Posted by Sierra360PDEK View Post
What kind of paint are you guys using?
Latex house paint, lasts for years.
Brewhedd is offline   Reply With Quote
Old 09-02-2016, 08:29 AM   #17
I use BEHR exterior paint on our doors & shutters & trim on our house !!!
GREAT PAINT !!!
Old 09-02-2016, 08:40 AM   #18
dieselguy's Avatar
An alternate to painting the shower sky light dome is to take down the inner lense and put a couple of layers of 1" bubble wrap inbetween the inner and out lense ... reinstall the inner lense. It makes quite a bit of difference and still lets the light in.
dieselguy is offline   Reply With Quote
Old 09-02-2016, 08:47 AM   #19
I would be afraid the Bubble Rap would blow up or melt !!!
Old 09-02-2016, 09:23 AM   #20
CaptnJohn's Avatar
I put MaxxAir covers on all vents when the 5er was purchased. Wish they made one for the skylight.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
show, shower
