Old 09-07-2016, 06:52 PM   #31
Originally Posted by DoubleDutch View Post
At this year's rally, friends explained how they went to Lowe's to get some solar film to put between their skylight. So, off to Lowe's for the solar film (located by the screen replacements), picked up a roll and split it in 1/2 with another CC friend. Ours works and still lets in some light - but does not allow the heat of the day to overwhelm you. It takes a #2 square drive and 8 screws to remove the inner part.
Glad it worked for you...hopefully it was as easy to install as I claimed
birdman77 is online now   Reply With Quote
Old 09-10-2016, 09:10 AM   #32
Wolverine 1945's Avatar
Originally Posted by dieselguy View Post
Replying to the comment on my bubble wrap alternate fix. I guess we all run I different circles of RVing. In my neck of the woods ... the bubble wrap install has been around for several years and has worked for a lot of RV'rs. I put it on my 3 previous Montana's and now my Silverback since the shower skylight is the same across brands. It does reduce the heat coming in, but it doesn't address the light issue that some are balking at. We don't mind the light, so that part isn't an issue to us. No worries on the stuff melting ... it just stays in place and knocks down a lot of the incoming heat.
When I think of bubble wrap I think of the stuff that shippers use,,,
Is that what you use ???
Wolverine 1945 is offline   Reply With Quote
Old 09-10-2016, 09:17 AM   #33
geezer with gadgets
757Dave's Avatar
We use this...
https://www.amazon.com/Reflectix-ST1...ble+insulation
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
Days camped 2015: 37; 2016: 66
757Dave is offline   Reply With Quote
Old 09-10-2016, 09:25 AM   #34
GreenImp's Avatar
Send a message via MSN to GreenImp
At about 2 years old our skylight cracked due to a combination of poor materials, poor workmanship, and a hail storm. I replaced it with one made of white lexan. It is fantastic...the heat has been greatly reduced without any noticeable reduction in light vs before. It seems to be the best of both worlds.
Got ours here..
RV Skylights, Square, Rectangular & Round.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 09-10-2016, 09:44 AM   #35
Made a cover for ours with a blanked out section to remove for cleaning. Just Eternabonded it to the roof 4 yrs ago and it still works. Sure cut the heat down.
ID:	119862   Click image for larger version
ID:	119863   Click image for larger version
Name:	View with removable cover after 3 yrs.JPG
Old 09-12-2016, 09:43 PM   #36
Alberta8311ss's Avatar
Just finished tinting the inside plastic of the sky light and painted the outside of the skylight trim black to keep the light down and to stop the uv. In hindsight now I should paint over the black with white to keep the heat down. My intention was to cut the light down not the heat.
Name:	ImageUploadedByForest River Forums1473734529.412811.jpg
ID:	120054Click image for larger version
Name:	ImageUploadedByForest River Forums1473734542.924264.jpg
ID:	120055Click image for larger version
Name:	ImageUploadedByForest River Forums1473734554.008596.jpg
2014 Rockwood 8311SS
Alberta8311ss is offline   Reply With Quote
Old 09-15-2016, 09:45 AM   #37
BDavis's Avatar
What type of paint?
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 09-15-2016, 05:02 PM   #38
Where you painted the outside of the trim I used an insulation material to help block heat. It's 1/4" thick by 1 1/2" wide medium density foam, a "Rubitex" branded pipe insulation with a sticky side, comes on a roll. Seems to help so far.
Thurman is offline   Reply With Quote
show, shower
