09-07-2018, 01:58 PM
Painting interior
I did a search but could not find an answer for this question.
Has anyone painted the dingy beige interior to white to have the interior lights reflect better? Even when on shore power it is pretty hard to do things like read or needle work. I know adding task lighting would help, but just want to make it brighter.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
09-07-2018, 03:02 PM
I just painted the inside of my trailer, I used tsp to wash down the walls, then you have to rinse well, I then put on a coat of "Glidden Gripper" primer /sealer.
waited 24 hours then painted final coat with Behr gave it 2 coats and looks great
09-07-2018, 03:08 PM
PICTURES!!!!!!!!!!!!
FROG AR-0019-242
09-07-2018, 03:11 PM
have you tried switching to "bright white" LED bulbs in the interior lights? This is a quick way to boost the brightness of the inside lights...
2014 Shamrock 183
09-07-2018, 03:28 PM
pics of painted wall
I have 2 more walls to go, I had one damaged area in the corner so I then just started peeling it off the walls, on the section just above the sink I left that contact paper on and used the tsp and rinsed very well.
09-08-2018, 09:39 AM
That white sure makes a difference against the beige. A lot brighter.
09-08-2018, 09:40 AM
I will look into that. Thank you.
09-13-2018, 05:56 PM
Lets go camping!
did you use the TSP all purpose?
and then rinse the walls with just water and sponge?
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
