04-17-2014, 03:53 PM
#21
I like the Old Coots set up easy to do with a door switch. He just used those strains of led lights. More then enough light, pretty clever for an old man with CRS. Probably even cheaper then the pucks. Don't need to buy batteries.
Coachmen M/H
Concord
2018 / 300 DSC
04-17-2014, 08:26 PM
#22
Hmmmm....I did a test of the puck light I was talking about. It did NOT work when it was dark. In fact, it needed quite a bit of light to pop on; however, you can always just push the light itself and it will pop on...but then it won't be automatic. Darn it! Wish I would have thought of it not working! LOL!! Never even crossed my mind. We will still get use of them.
04-17-2014, 08:33 PM
#23
Wow that is a great mod. Mine is like a dark cave you cant find anything. I did make some extra shelves out of that white laminated board yo get at Home Depot. What did you mean when you said it was accessible through the rear access door? Did you mean on the outside of the coach?
04-18-2014, 12:45 AM
#24
OC, that's a cool MOD for the cabinets! Neat!
-Forest River Sierra 355QBQ Bunkhouse
-2007 Duramax/Allison Stage 2 Garrett Turbo W/ KB3MMX EFIlive custom tuning & lots of other goodies...
04-30-2014, 07:32 PM
#25
Pantry Lights
04-30-2014, 10:23 PM
#26
Confused on LEDs? Can I purchase LEDs for the fixtures I have? If so, where can they be purchased. Do not what to do any modifications, not in my skill set!
Sharon & Jim, Dutchess
Windjammer 2102w
Ford f150 4x4 EB 2014
2012 30, 2013 25, 2014 29, 2015 37
05-01-2014, 04:54 AM
#27
Toy-aholic
Originally Posted by Pacostaco
Ok, I couldnt let someone out do me so I set out to do my own pantry lights. I used a strip LED light that has a 3m double stickk tape on the back side. It is from wholesale-leds.com. I also used a micro switch to turn the lights on and off when the dor opens. I drilled a hole into the bottom of the cabinet from the outside refrigerator access panel. Using a volt meter I located a DC connection, loosened the screws and attached my wires. Amazing difference.
how about a shot of that micro switch?!
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
05-01-2014, 08:06 PM
#28
Pantry Lights
There is a pick of the micro switch but hard to make it out. Attached is a new one in the package. It is a nice switch because you can wire it 2 ways. So when door opens light comes on or when the door closes the light comes on, depending on your application.
05-01-2014, 08:16 PM
#29
look up starlight they have any size you need and want, but pricey.
Coachmen M/H
Concord
2018 / 300 DSC
05-05-2014, 07:30 AM
#30
There is a pic of the micro switch but hard to make it out.
Switch source?
Chris Cowles
Gainesville, FL
Former pop-up owner
Hybrid owner wannabe
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
05-05-2014, 07:33 AM
#31
Originally Posted by chriscowles
Switch source?
Chris Cowles
Gainesville, FL
Former pop-up owner
You can get micro switches on eBay.
05-05-2014, 07:49 AM
#32
Light Power Source
I got the power from the refrigerator access panel on the outside of the rig. I used a volt meter to find a 12 volt DC source. It turned out to be that little plastic coupler that had 2 wires coming from it. You can see my wires they are red and black. I simply loosened the screws holding down the green and white wire and inserted my wires and re tightened. The green wire was the positive.
