Old 03-14-2013, 01:53 PM   #21
New to Forest River
Originally Posted by jnamadison View Post
Mike,
Have you happened to try these out yet? Was wondering what size the pantry cabinets were. My rig happens to be an hour away until next weekend.
Thanks.
No, DW wants to leave it like it came for now. We'll see.
Mike & Tracy Boyd
2013 LaCrosse 318BHS Touring Edition - Forest River - Prime Time
2006 Silverado 2500HD 4x4 Crewcab SB DMax/Allison
Graduated from 1999 Dodge Ram Extended 2wd 5.9L &
2005 Prowler Lynx Ultralite 29BHS
Mikedboyd is offline   Reply With Quote
Old 03-14-2013, 02:03 PM   #22
I can understand that. Once my DW gives the go ahead. I'll do the install and post up some pics.
John & Amy
jnamadison is offline   Reply With Quote
Old 03-14-2013, 08:14 PM   #23
clancythecamper's Avatar
We got a new ad from Bed Bath and Beyond this week. It has some really good organizing stuff, basket drawers, clear containers, etc that might be useful. Also a $5 coupon on the back I picked up a fridge thermometer, some scented contact paper to line my new closet shelves, and a new scent for the wax warmer from Yankee Candle called Treehouse Memories ~ nice woodsey scent
clancythecamper is offline   Reply With Quote
Old 03-21-2013, 04:25 PM   #24
Just wanted to add my thanks to Herk for the amazing amount of (always) complete information he has contributed over the years. Much appreciated.
tom.keith is offline   Reply With Quote
Old 04-02-2013, 03:22 PM   #25
ok, newbie here....what does "DW" stand for? I'm hesitant to guess
boatnut is offline   Reply With Quote
Old 04-02-2013, 03:25 PM   #26
B47
Don't be - DW - Dear Wife, DH - Dear Husband, DD -Dear Daughter etc.
Old 04-02-2013, 09:51 PM   #27
New to Forest River
Try this thread over at RV.NET
RV.Net Open Roads Forum: Travel Trailers: list of the abbreviations everyone uses?
Mike & Tracy Boyd
Old 04-02-2013, 10:12 PM   #28
New to Forest River
and after one weekend in the new camper, I have now purchased the chrome slideout shelves from Lowes and am also going to be getting some white wire basket pullouts for the top shelf of the pantry. I also have a task to find some way to add some electrical outlets on the outside wall behind the sink/stove.
Shop Rev-A-Shelf 2-Tier Metal Pull Out Cabinet Basket at Lowes.com
ClosetMaid 11 in. 2-Tier Cabinet Organizer-3608 at The Home Depot
Mike & Tracy Boyd
Old 04-03-2013, 06:34 AM   #29
I like all these ideas but in our Wildcat, becasue of the knob the pantry doors do not open a full 90 degrees. This means I need pull-outs that are only about 10" wide. Looks like the only alternative is to add weight to the RV by constructing my own pull-outs out of wood.
JJnLilly is offline   Reply With Quote
Old 04-03-2013, 11:22 AM   #30
Steve Jackson
sideout1961's Avatar
Can someone tell me what size screws are used when attaching the bars to back wall of pantry for the wire shelves? I want to hang some this spring and don't know how deep I can go with the screws. Just wondering what everyone else has used.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 04-03-2013, 11:28 AM   #31
If you arent inclined to modify the basket sliders at lowes, etc. I would suggest checking online at the container store. I saw lots of great things there (if you're willing to pay for them)
Old 04-03-2013, 11:29 AM   #32
The Container Store - The Original Storage and Organization Store®
Old 04-03-2013, 12:20 PM   #33
If you are concerned about it you might consider attaching to the bottom of the cabinet instead. Mine are just box construction cabinets so I screwed into the rear cabinet support across the back edge. I did the same at front. Just a thought.
Tblackmon9599 is offline   Reply With Quote
Old 04-03-2013, 12:27 PM   #34
Steve Jackson
What did you use for the shelf support? Did you just screw in blocks for the shelves?
Old 04-03-2013, 12:43 PM   #35
Another way would be to mount your door to the pull outs ( remove the hinges If you check kitchen designs some pantry's are made this way. This effectively makes a large vertical drawer front.
08 Titan Crew Cab Long Bed with Big Tow
13 Surveyor SV 291
New Holland TC45
Polaris XP550
Berkshireba is offline   Reply With Quote
Old 04-04-2013, 08:20 AM   #36
Sorry late reply. Tied up at work.
I used the Lowes brand shelves and they have a thin metal bracket along the front and back that you use to mount to cabinet bottom. Obviously if you are using another type that may not be an option.
Old 04-04-2013, 08:23 AM   #37
Here is a link to the ones I used:
http://www.lowes.com/pd_224083-94604...+cabinet+shelf
Old 04-12-2013, 12:06 PM   #38
New to Forest River
Live and learn - I put in the 2-tier version of the Lowe's shelf linked just above. The upper shelf has our liquer and cooking oil, etc. on it (taller shelf). My first driving with the shelf in place was just the 10 minutes from the storage lot to our house. When I got in the trailer to start loading stuff in for the weekend, I found both shelves fully extended and the cabinet door in pieces. The part attached to the hinges was still attached and the part with the handle was on the floor. Kinda came apart where the panel was glued together. I've got a temp fix in place (I hope it works) with an eye-bolt in the side shelf support and some stiff wire through it and around the top shelf frame, plus a metal shim holding the lower shelf to the upper shelf. Thinking about drilling through the shelf guide into the side support and putting a pin of some kind in for travel. I've re-glued the door and it is almost good as new. I'll re-mount it at the campground this evening. sigh
Mike & Tracy Boyd
Old 04-12-2013, 01:44 PM   #39
Sorry to hear that. I use baby cabinet locks to keep doors from opening. Cheap and quick. Just food for thought.
Old 04-12-2013, 01:57 PM   #40
New to Forest River
it's really more that I have to stop the sliding shelves from sliding. They are only about 1/4" from the door, but I still wouldn't it banging into it. thanks though
Mike & Tracy Boyd
