Old 09-08-2018, 06:10 AM   #1
PD4655 Install Question
I installed a pd4655 converter/charger and was wondering what the small black switch was on the main circuit board? It has a red light next to the switch?
ftroop82 is offline   Reply With Quote
Old 09-08-2018, 07:33 AM   #2
It is used to manually switch between the 4 charge modes. Read the manual concerning the charge wizard and it will explain the function. Typically there is no need for you to use the switch as the converter will switch to the proper mode based on battery voltage and time.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is offline   Reply With Quote
Old 09-08-2018, 08:24 AM   #3
Should the red light be on next to the switch?
Old 09-08-2018, 08:47 AM   #4
Typically the charge wizard has a green led for mode status.
The green led is above and to left of the switch.
The red leds (on this model there are 12 of them, in a straight line to the left of the switch) are to indicate a blown fuse on one of the 12 volt load circuits. Keep in mind the fuse blown led will only illuminate if a load is present on that particular circuit and the fuse is open.
Old 09-08-2018, 09:02 AM   #5
This red light and switch is on the main converter circuit board not the 12v board
Old 09-08-2018, 09:38 AM   #6
Sorry I thought you were referring to the power distribution board.
My guess and this is only as guess as PD does not have any available literature re what you are describing, is that the switch, and only if it is a maintained contact is to select the battery type. PD has typically used a jumper to do this but it may have changed. As far as the LED maybe it's just a dc on indicator. Looks like a call to PD may be in order.
Old 09-08-2018, 10:16 AM   #7
Sorry, I`m an idiot, I went to take a closeup photo and the switch that I saw was really a raised circuit chip and after unplugging the rv the red light went out, so the light must show that ac current is on.
Old 09-08-2018, 10:25 AM   #8
Iwannacamp's Avatar
Welcome to my world.....blind
2017 Puma 297RLSS
Old 09-08-2018, 02:00 PM   #9
Old 09-08-2018, 02:15 PM   #10
LOL!
