Old 08-10-2016, 01:39 PM   #1
Kenny kustom's Avatar
PI gen plug
Are people needing to use the PI gen plug for the ground neutral bonding issue??
I looked at the plug, $18 bucks.
Not bad.. could probably make it just as easy.
Put it in the cart... $75 SHIPPING TO CANADA!!?? Holy crap!
Um.. nope
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 08-10-2016, 01:42 PM   #2
karrun's Avatar
Is this something you can make yourself? I'd be interested in doing that.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is online now   Reply With Quote
Old 08-10-2016, 02:20 PM   #3
You sure can.
Just take a plug and put a wire between the neutral and ground.
CAUTION. DO THIS AT YOUR OWN RISK..
2016 Sabre 36QBOK
Old 08-10-2016, 02:33 PM   #4
wmtire's Avatar
Mike has the instructions on his No Shock Zone website on how to make these:
Generator Ground-Neutral Bonding | No~Shock~Zone
and he also has a youtube video demonstrating them in action
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
Old 08-10-2016, 06:14 PM   #5
I got an error 9 on my Pi when I plugged it into the Yammy.
Data link error... hmm
2016 Sabre 36QBOK
Old 08-15-2016, 01:31 PM   #6
Originally Posted by Kenny kustom View Post
You sure can.
2016 Sabre 36QBOK
^^^This. All that is being done is connecting the Neutral with the Ground.
Buy a plug, connect the neutral and ground, plug it in to the gen.
I can explain what/why/where/how/etc. if more info is needed.
325BH is offline   Reply With Quote
Old 08-16-2016, 05:21 AM   #7
Learjet's Avatar
Made myself one and fixed issue with PI EMS for RV.
FYI...Same bonding happens when plugging generator into house through interlock device, neutral and ground get bonded at the main panel.
-2013 Ford F250 XLT 2wd Crew Cab 6.2 with 3.73
-2015 Wildcat 317RL
-B&W Patriot 18k, MorRyde, Timbrens
Learjet is offline   Reply With Quote
Old 08-16-2016, 09:52 AM   #8
Yup. In your house, the neutral and ground are bonded at the main.
Since bonding of neutral and ground are to occur in one location only, this is the reason some generators are not bonded. You don't want the generator bonded when plugged in to your house.
At the campground, bonding occurs somewhere upstream, possibly at the pedestal. Because of this, there is no bonding in the camper's main panel... and is why the generator should be bonded when powering the camper.
In the case of powering the camper, not only should the generator be bonded it should also be grounded with a ground rod... but I never see that.
