Old 04-27-2013, 04:56 PM   #1
Rolling buckeye's Avatar
PI surge protector wont turn on power
Installed PI surge protector with remote display,when plugged in to house,getting 123 60H E-0. When I plug in to new Boily gen set it reads e-2 "open ground" and will not turn on power. Using proper cord,with 30 amp 3 prong end. Tried with adapter plugged in to reg outlet on gen set,tripped power on gen set. In the instruction book from PI,it states "do not plug in to inverter" the Boily is an inverter gen. Is this the problem? Others must be using inverter type gen sets,
Thought to call customer serv. at PI,but sat 5:50,too late,so thought I would pick Y'all's brains first! Help !
Rolling buckeye is offline   Reply With Quote
Old 04-27-2013, 04:59 PM   #2
TURBS's Avatar
Ground your gennie with a rod stuck in the ground and wired to your gennie.
Most gennies have a wing nut and a post to attach the wite to.
Old 04-27-2013, 05:01 PM   #3
TURBS's Avatar
Basically your gennie has no earth ground unless you do this.
Old 04-27-2013, 05:02 PM   #4
Thanks Turbs ! I'll go try! U Da Man !
Old 04-27-2013, 05:03 PM   #5
TURBS's Avatar
Drive your rod into the ground a foot or so then attach a wire with a hose clamp to it.
Then hook loose end to gennie ground lug as pictured above.
Turbs
Old 04-27-2013, 05:03 PM   #6
TURBS's Avatar
All I got to say is BBC!
Old 04-27-2013, 05:37 PM   #7
fonzie's Avatar
I don't think grounding your generator to a ground rod will make a difference. In a normal house supply the ground and neutral are tied together in the electrical panel but not in the generator (not mine which is a Yamaha) So either you bypass your PI surge protector on your remote display or you need to do an adapter. See attached.
File Type: pdf Special Generator Pigtail Instructions.pdf (132.6 KB, 63 views)
Fonzie
Old 04-27-2013, 05:41 PM   #8
TURBS's Avatar
Your house power is also grounded to earth.
My EMS showed same fault till I earth grounded my gennie.
Old 04-27-2013, 05:43 PM   #9
Turbs
Roger . These are my connections. Still E2-PE2
Opened panel on front of Boily, n checked,ground bolt I att. to is wired to grnd o rec's and to gen frame. ???
Old 04-27-2013, 06:03 PM   #10
Ok bypass worked, but darn ! Would have been nice to monitor gen power too!
Next Problem.....
Aaaaaaaa. BBC .... Box ...... EMPTY !! The HORROR ! What do I do now !
Beerun !
