Old 07-12-2016, 09:55 AM   #31
Originally Posted by BDavis View Post
Our Dometic AC units have black cowlings. Would painting them white really make that much of a difference?
Actually, black on the back half (condenser) may actually be better. As I learned in engineering school, a "true black body" will absorb all incoming heat if colder, but will give off heat if warmer. So black will dissipate the internal heat better than white, while white reflects external heat better than black.
So, in theory, better to have white on the evaporator cover and black on the condenser cover. But it would take some experimentation to prove it.
And the amount of "improvement" is probably not even worth worrying about.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 07-12-2016, 10:07 AM   #32
Georgia Frog Rally 2017
aceinspp's Avatar
This one reason why motor vehicle engines are painted black. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 07-12-2016, 10:27 AM   #33
Herk7769's Avatar
Originally Posted by Jimandchris View Post
Herk, do you happen to remember what size the refrigerant line is that needs to be insulated? Great looking mod and I have plenty of reflectix left over for evaporator box - may as well do it all at once.
Thanks!
The large diameter pipe is cold when running and that is the one you insulate. The small one is hot when running so you should not insulate it. I do not see any need to insulate the hot section as you want THAT heat to leave the enclosure.
HAM CALLSIGN - KC3FFW
Old 07-12-2016, 10:30 AM   #34
jeff
jeff64's Avatar
Anyone have experience doing this mod with something other than reflectix? The bubble wrap material seems a little flimsy to me and the R values, from what I've read are more like R-1 than R-5. The overall concept here seems to be a winner. Would like a more robust material with a better or at least consistent R- value. I'm leaning to Frost-King Aluminized duct wrap, self adhesive, R-3 on the air handler housing. The cost is comparable
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-12-2016, 10:56 AM   #35
MarkyB's Avatar
I've done similar mods to my Jeep.
Insulated the cold pipe in the engine bay, and lined the inside of tub with the reflectix. The insulated pipe makes the a/c blow just a little bit cooler... The reflectix under the carpet helps with heat transfer through the floorboards. It's about changing the percentages in your favor just a little bit. Even if it's "1%", the result is the Jeep is nice and cool even with a soft top 95 degree weather.
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
MarkyB is offline   Reply With Quote
Old 07-12-2016, 11:11 AM   #36
Herk7769's Avatar
Thanks!
Not 100% sure but I think I used 1/2 inch pipe foam insulation I had around the house.
Old 07-12-2016, 06:41 PM   #37
1/2"
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 07-12-2016, 09:27 PM   #38
Captain America's Avatar
1/2" is what I used
2011 Wildcat 32QBT
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor
Jack of all trades, Master on none
Captain America is offline   Reply With Quote
Old 07-30-2016, 09:14 PM   #39
Fire Instructor's Avatar
There's a parallel thread to this running over on the Jayco owner's forum, where I now spend most of my 5'er forum time..... It was mentioned that the tread, and the idea originated on the Forest River Forum, and I said to myself that it looks like the kind of thing that Herk would try.... So, I looked for it today, and lo and behold! Herk's the guy who started it! LOL!!!
Disregard the info in the sig. Traded the Rockwood for a North Point (Jayco) 377RLBH late last Fall. Took all of the solar stuff off the Rockwood and reinstalled it on the 377!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 07-30-2016, 09:26 PM   #40
SeaDog's Avatar
It a good move to insulate the suction line (cold as you call it) it will help the AC run a little more efficiently. I have done this to mine and added a hard start. I plan to do the reflex soon. good job
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
