Old 04-16-2015, 04:45 PM   #1
Portable Generator Installation
Has anyone seen, done or heard of anyone installing small portable generators in their 5th wheel. Don't know that I actually would do it but I have extra room in the storage space under the over hang. I purchased 2 ef2000is Yamaha generators and was thinking it would be kinda nice to be able to run them while in the closed storage hatch. Obviously I would need to run exhaust and install a couple of fans to keep them cool and maybe even some noise absorbing material to quiet them down even further. Think of a generator quiet box/baffle box but more permanent. Again folks I am just thinking out loud and would like to hear you input and ideas. Thanks.
Name:	Rv Storage.jpg
zork is offline   Reply With Quote
Old 04-17-2015, 04:59 PM   #2
B and B's Avatar
I am not sure you could make the bay gas tight not to mention fumes from fuel itself. Might be best to leave outside for safety. I have been thinking about a silencing box for my new generator.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-17-2015, 06:06 PM   #3
Fabricating an exhaust system that does not leak inside the unit would be the biggest challenge. Followed by venting to allow fresh air into the generator compartment. They are air cooled engines and will require good airflow to avoid problems.
For me the risk of carbon monoxide poisoning just isnt worth it.
2014 Coachman Clipper 17FQ
2011 Ford Ranger 4X4
Kenrod is offline   Reply With Quote
Old 04-17-2015, 09:41 PM   #4
Left Coast
Also, would need to create an extended stay type fuel tank, or you'll be doing more lifting and then, if the exhaust isn't a slide together type, another thing to deal with. Or, a pull-out tray. Old dinning room table that has leaves also have stout hardware for runners.
Old 04-18-2015, 12:30 PM   #5
RPAspey's Avatar
A local band has a utility trailer with portable genny built in. I asked to check it out during a show last fall. The manufacturers simply built an aluminum box sized to fit the generator + about 12" all around. It was all welded joints. Then bolted with gaskets, to the inside of the trailer. The new generator compartment had its own outside door with louvers. The genny exhaust was right at the door, pointing through a hole. No other fans or vents for cooling. The genny was mounted on full travel heavy duty slides. So to service or fuel up, the door was opened, and the whole thing slide out. All connections were flexible cord.
Now, I personally would feel uneasy about running it in the compartment, but would have no problems sliding it out and running it.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 04-18-2015, 04:16 PM   #6
Left Coast
That's the way most race car trailers are.
Old 04-18-2015, 09:11 PM   #7
RPAspey's Avatar
Oh, I've never seen a race car trailer. Funny thing is my inlaws are big time into Sprint car racing.
Old 04-19-2015, 05:55 AM   #8
We picked up a 3500 watt champion gen at tractor supply just set it in the truck bed , made a cord to reach right above front storage bay, installed a plug ,then ran wire to panel box now we run gen to run front ac while driving ,just be sure to unplug it BEFORE plugging inton shore power
rwehba is offline   Reply With Quote
Old 05-19-2015, 11:28 PM   #9
I was thinking along those lines as a down and dirty way out for my 2005 Cardinal as I too want to run the generator when on the road in the event that I transport dogs to a show in it. My concern with this is CO infiltration into the trailer still. Right now I'm leaning toward the Kohler LP line because that is what would have been installed in the front compartment. Obviously anything done will require the installation of CO detectors. LP is cleaner burning. I have also been looking closely at the inverter generators but there is still the problem of long run fuel storage and gasoline or diesel fumes both pre and post combustion.
Where is your panel box? Mine is in the rear so I would have to run wire all the way to the front either way I think.
73's KC5CGU
2002 F250 Crew Cab Short Bed 7.3L 4x4
2005 Cardinal 29WB 5th Wheel
Lana - Copilot / Navigator / CFO
Champ & Fiona 2 ea. Standard Schnauzer Security Detail
mtnpeak is offline   Reply With Quote
generator
