Old 03-23-2014, 10:25 AM   #41
Originally Posted by gljurczyk View Post
No I didn't, what thread is it? all I know you do is throw a line over the awning like a you know what... Please repost it so I can see what a genius you are. Is your arm getting tired yet or you back getting sore? Just want to know?...
How about a search Power awning deflapper?
Old 03-23-2014, 10:30 AM   #42
rsibarra2010's Avatar
Originally Posted by OldCoot View Post
PM was sent.
I haven't gotten a pm. Could you please resend?
rsibarra2010 is offline   Reply With Quote
Old 03-23-2014, 10:37 AM   #43
iowaborn's Avatar
Send a message via AIM to iowaborn
[QUOTE=OldCoot;569511]
Post some pictures of yours before you mount them. Other folks might be interested.
Not a very good pic, but it does show the difference a little polishing will make. On the left is how it looks as received from OC. The right two poles have been polished using Mothers aluminum polish.
2013 F-250 CrewCab 6.7 PowerStroke 4X4
2017 Silverback 33RK
iowaborn is offline   Reply With Quote
Old 03-23-2014, 10:40 AM   #44
Witch Doctor's Avatar
[QUOTE=iowaborn;569579]
Yep they look great without buffing for 3 hrs. That's what I did.........
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-23-2014, 10:40 AM   #45
Looks like DW is doing a very good job! Nice!
Old 03-23-2014, 10:41 AM   #46
I wouldn't put such a thing on my unit, all your doing is pulling down and stretching your fabric down, You call that a break through. I would think that you could do better then that being an engineer. Thats a rookie fix thats bad for your awning IMO. But you never listen to me anyway and I know you been camping for 30 years Da, DA DA.......
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-23-2014, 10:41 AM   #47
[QUOTE=gljurczyk;569580]
On one set.
Old 03-23-2014, 10:45 AM   #48
NELA
Weezer's Avatar
Originally Posted by SYE View Post
No pics, didn't happen!!!
pppffffftttttt
Pics will happen when the job is finished.
I ain't goin' out to his shop to take a pic right now, I'm still in my granny gown!
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 03-23-2014, 10:59 AM   #49
Doesn't stretch it anymore on the power awning than on a manual. Is you tipping the bottle so early?
Old 03-23-2014, 12:16 PM   #50
mark0224's Avatar
Originally Posted by 09grizzly1 View Post
mark0224,the power hook awning tensioner has a part that hooks into the awning tube slot. When positioned correctly, it will turn the awning tube to tighten the fabric.
risibarra2010,I use that with my electric awning with my version of OldCoot's awning poles and it works good. I do not recommend using it on an electric awning without the poles as the arms may bend or the arm lock knobs may not hold. I attach the springs to the ground directly beside the poles(dogs are less likely to get tangled around the strap).
09grizzly1
Already Made my own poles and will only be applying light pressure until I check it out. The strap I made will more hold the roller to the uprights I made and is only about a foot away from the poles so it really shouldn't get in the way but used orange straps for visibility. The straps worked great alone with out poles on my manual awning on our old trailer, just enough tension to pull a bit on spring. Spring acts like shock absorber so tension stays the same because of it. Less pressure than a light wind can put on it.
mark0224 is offline   Reply With Quote
Old 03-23-2014, 12:23 PM   #51
A lot of ways to "skin a cat". We lazy old folks like stowing them on the arms for 2 reasons, we can find them and we don't go off and leave them.
Old 03-24-2014, 05:54 PM   #52
mark0224's Avatar
These are just the start working on the brackets to fasten them to the uprights but weather hasn't been cooperating. Still only in the 20's here. Using these for our first trip since time is running out and cold isn't. Poles themselves will work good and there is always room for improvement.
awning, power
