Forest River Forums
Sunline User Photos
Old 11-08-2011, 12:41 PM   #11
Smile
What does your battery box look like, and where is it on your trailer? I have an XLite 26BH, and have been trying to figure out where to put a battery box.
tzalmaves is offline   Reply With Quote
Old 11-08-2011, 04:25 PM   #12
Fire Instructor's Avatar
I replaced my factory battery box with a 12" wide pick-up truck tool-box, Kobalt brand, from Lowe's. I currenly have two batteries, four sets of Linx Levelers, some homemade stabilizer jack pads, a couple of pieces of 4x4, and some other "stuff" in there. I've only gotten into the third Linx kit once, so likely I'll "loose" two of those next season, and that will give me more than enough room for two more batteries.
I had to move the propane tanks forward anout 1.5" for everythning to fit.
Be safe, and Everyone Goes Home!
Fire Instructor
2004 RAM 1500 4x4 Quad Cab w/Hemi, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 11-08-2011, 04:33 PM   #13
I'm looking at doing the same thing, but I think the box will cover the weight distribution chain receivers on the RV. Do you have a photograph of the box installed? -TM
Old 11-08-2011, 04:57 PM   #14
Mine would have also been partially in the way of the WD chain clamps, but what I did was to support the entire box with two pieces of 4' long, 1" Uni-strut channel (also from Lowe's). This gave the box support beyond the trailer A-frame, plus it raised it enough that the chain clamps are partially under the box. It's all a tight fit, but it all fits!
My only problem was backing in my driveway, it's such a sharp cut, that the corner of the bumper hit the box, and put a slight dent in the box. I've learned not to cut quite so sharp when backing.
Sorry, no pics of that, and the TT is winterized, covered, and the batteries are in the basement. Nudge me in the Spring and I'll shoot you a pic, if you still need it.
Fire Instructor
Old 11-08-2011, 11:22 PM   #15
Is yours this side truck box (4' long and wider at the top)? http://tinyurl.com/cytpss5
What does the cross section of Uni-strut look like?
Old 11-09-2011, 05:56 AM   #16
No, I believe that it's this box: Shop Kobalt Slim Line Full Size 12" Truck Box at Lowes.com
Uni-strut is the U-shaped channel, usually bolted to walls or the underside of roof trusses in commercial buildings, ised to clamp electrical conduit to. Here's what it looks like: 01052011_Unistrut_US
I used the P1000, available at most big-box building materials stores. I just used it as a spacer/stiffener under the aluminum box.
Hope that this helps!
Fire Instructor
» Online Users: 538
91 members and 447 guests
12vdzl, 4bnabird, 4runner freak, 8261ss, abjb, backpacker3, Barney1, Bearcat55, bfisher82, bikendan, bob7794, bouldercamper, brania, buzzmonster, campfun, CampinQueen, Canuck_Doug, carsonizik3, chiro, ClampNfish, cmptrkd, cousin01, Cowracer, cstover, dashonthedash, daw592, depo, djorgensen3, dlmurray51, DonCath25ds, DonG, donh, donn, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, JJFerg, JLcampgirl, Joseph5410, kgmat, KKapa, Lonewolfcry, ltypd, Mad4sax, mcdiver, mike1329, Mkayers, Mpwelch50, mtnguy, NeilM108, onetonford, Pa-cj5, Pinesman, Poppy Bill, PrairieBoy, punkaccountant, rbrandon, rglickman, RichN, Riva, Roamin Ovum, rschroe, Rugged Brown, Russ, Scriggs1, seatosea, Sparkbark, SpringerPop, tfennell81, TheSasks, Titleguy, Tom993, tonybab, troyt, UPGRADER, VTX Al, wbdvt, wfmdfm, Whiskeyjack, Whiteknight, whj77372
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
