Old 03-31-2013, 09:25 AM   #11
Denver, CO
garbonz's Avatar
The little button in the center between the terminals is the reset. May be corroded tho.
2017 Fuse 23T
garbonz is online now   Reply With Quote
Old 03-31-2013, 10:18 AM   #12
Rolling buckeye's Avatar
Sorry this is a better pic, what may look like a button,is just a casting mark in the plastic cover.
I found a replacement at AZone,only no reset button ether,the cover will work with the replacement,but there are two 8 ga. wires,and two 18 ga. both with ring terminals, that is a lot of stuff in the way of the cover,so it still will not protect the terminals. Think ill just spray battery terminal protectant on them.
Rolling buckeye is offline   Reply With Quote
Old 03-31-2013, 11:47 AM   #13
Finished install! I found a loose connection on + side,factory crimp not good replaced with new copper eye.this is probly what shorted the auto reset breaker.i purchased an extra auto reset breaker just in case,will add to emergency electric kit. All works fine now.
Thanks for all the help!
Old 03-31-2013, 12:49 PM   #14
Looks good.
2012 dodge ram 3500 dually
2008 sandpiper 305RGS.
Horns07 is offline   Reply With Quote
Old 04-02-2013, 12:09 PM   #15
great looking set up.
2011 Ram Laramie
2010 Rockwood 8319ss
2010 Polaris sportman 300(wife's)
2005 Polaris sportman 500HO (mine)
trailraider is offline   Reply With Quote
Old 04-13-2013, 06:38 PM   #16
Sorry don't know yet how to caption ea. pic.
Installing cabs in garage,yet to be stained "dark cherry" ,tops and flats in panels will be coated w rubberized bed liner roll on.
Installed mirror tint on sliding glass door. Pics w open / closed
And 24" TV in master
Will post pics o cabs after finish.
Big cab is a chest type, for grill n prop bottle air comp,tools n such.
ID:	27838   Click image for larger version
ID:	27839   Click image for larger version
ID:	27840   Click image for larger version
ID:	27841   Click image for larger version
Old 04-13-2013, 06:55 PM   #17
AquaMan's Avatar
I'm now feeling a bit guilty for doing absolutely nothing today! Great looking mods RB!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-22-2013, 04:34 PM   #18
DougP47's Avatar
Rolling Buckeye Great Looking MODS
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 04-22-2013, 04:48 PM   #19
Originally Posted by ttrost65 View Post
I'm now feeling a bit guilty for doing absolutely nothing today!...
Me too, but I'll drink a cup of coffee and get over it.
Mods look great!
Old 04-22-2013, 05:16 PM   #20
Thanks gang !
Just finished last coat of bead liner black on tops,will finish tomorrow,n post finish pics. Un fortunately,I had some bleed through at tape,on som trim. that liner spray is not coming off.and I did an ok job on stain,could be better,but I'm not doing it over.its in and will do what I want. I put magnate catches at top and bottom of doors,but may have to think of something else,they are not really strong enough,to keep heavy objects in cabs.
I am supposed to receive a 30 amp progressive hard wire/remote monitor, wed. Hope to get it in this wknd.
And need to make a home for new gen set, which fired right up,ran about 1/2 tank o gas through,then ran some power tools with it. Worked great ! Hope it stays that way.
