03-24-2015, 11:37 PM
Progressive 50 amp EMS install
Another item in my mods for 2015 is install a Progressive 50 amp EMS / surge protector. I wanted to place the unit in a location where I could easily access it, should an item need replacing. In my Coachman 360IBL the 50 amp service is accessible underneath the stairs. I freed up enough slack in the service line to mount it there without adding additional wire.
50 AMP SERVICE LINES ARE A PAIN!!! Super stiff, difficult to cut, etc.
Picture 1: Take off the 2nd step vertical front cover. Service line can be found here.
Picture 2: I've cut the service line.
Picture 3: Ready to install.
Picture 4: Inbound lines ready.
Picture 5: Location under stairs.
Picture 6: Fully mounted and ready EMS.
Picture 7: Bunkhouse remote head unit. I attempted to run the cable through the wall but there is a board that prevented this. I ran the wires externally in the bunk room. I wanted the doors to properly close around the remote head which required me to recess the mount. I liked the idea of the remote head easily accessible, but yet not flashing bright lights all the time. This location allows me to close the doors. I also added a battery voltage monitor.
Picture 8: Remote head. (I'm going to take the white caulking off because it turned out horrible)
2015 Coachman Chaparral 360IBL
2012 6.7L Ford F350 SRW
53 nights camped in 2017.
03-25-2015, 12:02 AM
did you figure out the jumper thing for the delay? i even called them and still could not understand where the jumper was to adjust the kick back on time cycle and said hell with it and just installed it. Yes the 50 amp wires suck trying to get the wires in the terminals. Looks good nice clean install
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
03-25-2015, 12:26 AM
I left it as is (15 second delay). My coach has new enough AC / Thermostat that will delay starting the ac compressor in the event of a power failure. Older coaches sometimes don't, which is why they have the jumper.
03-25-2015, 07:51 AM
Let's see if this works from Sept. 19. 2014. CLICK on each attachment name.
Originally Posted by Mr. Dan
Jumper ON
Attachment 63066
Jumper OFF
Attachment 63067
Text with pics: 'you can find it next to the receptacle for the data cable. It is a small black plastic square (¼ x ¼ inch) mounted vertically. It is next to a small yellow capacitor and exposes two metal pins'
Sent (I think)
03-25-2015, 12:15 PM
Nice install. Thanks for the pictures!
03-25-2015, 09:22 PM
Showed this thread to DH. Definitely something we will do on our 360 IBL but will have to wait until we get new tires and some necessities for inside. He just put it on his TO DO list. This weekend he's putting on the JT strongarms that you had previously recommended.
03-25-2015, 09:40 PM
Buying and Installing one of these Progressive EMS HW50C is at the top of my to do list. I do a lot of internet shopping in search for the best price. So far this is the best that I've found $315.85 free shipping at Progressive Industries EMS-HW50C Hardwire RV Surge Protector 50 Amp
Did you find a better price, if I may ask?
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
03-25-2015, 09:42 PM
Nope that's the best I've seen. Buy it!
03-25-2015, 09:50 PM
I got mine here: RV Safety Accessories Inc $305.00
03-25-2015, 09:54 PM
Even better THANK YOU. I hope this goes like a auction in reverse and the price keeps dropping, but $305.00 likely won't be beat...
03-25-2015, 10:00 PM
03-25-2015, 10:14 PM
Originally Posted by TURBS
Is shipping extra?
The eBay version does not have a remote display.
03-25-2015, 10:16 PM
SO... check for internal/external display and shipping charges.
03-25-2015, 10:24 PM
Tweety' s does have shipping charge. Just got mine last week. Nice looking install.
2011 Georgetown 337 2011 Chevy Impala
03-25-2015, 10:50 PM
I think I would do some reading on that. Your stat is 12 volt, if you lose power 110 volt you still have 12 Volt running that is what controls your time delay through the stat. If you turn your stat on it will delay but when you lose power 110v. You do not lose 12v which controls your time delay. So as soon as 110v comes back your stat never recognized the lost of power and it would try to start. At Least that is my understanding and it makes sense if if you think about it....
Coachmen M/H
Concord
2018 / 300 DSC
03-26-2015, 09:11 AM
I called Dometic & Coleman (my AC mfg). They said there was a timer or sensor that would delay compressor startup in the event of a power failure. This has been a standard feature for "many years" they claimed. The reason for the delay is to prevent the compressor(s) from starting up too soon when there is still high pressure in the lines. Compressor damage may occur.
