Old 03-24-2015, 11:37 PM   #1
farmncamp's Avatar
Progressive 50 amp EMS install
Another item in my mods for 2015 is install a Progressive 50 amp EMS / surge protector. I wanted to place the unit in a location where I could easily access it, should an item need replacing. In my Coachman 360IBL the 50 amp service is accessible underneath the stairs. I freed up enough slack in the service line to mount it there without adding additional wire.
50 AMP SERVICE LINES ARE A PAIN!!! Super stiff, difficult to cut, etc.
Picture 1: Take off the 2nd step vertical front cover. Service line can be found here.
Picture 2: I've cut the service line.
Picture 3: Ready to install.
Picture 4: Inbound lines ready.
Picture 5: Location under stairs.
Picture 6: Fully mounted and ready EMS.
Picture 7: Bunkhouse remote head unit. I attempted to run the cable through the wall but there is a board that prevented this. I ran the wires externally in the bunk room. I wanted the doors to properly close around the remote head which required me to recess the mount. I liked the idea of the remote head easily accessible, but yet not flashing bright lights all the time. This location allows me to close the doors. I also added a battery voltage monitor.
Picture 8: Remote head. (I'm going to take the white caulking off because it turned out horrible)
ID:	72131   Click image for larger version
ID:	72132   Click image for larger version
ID:	72133   Click image for larger version
ID:	72134   Click image for larger version
ID:	72136   Click image for larger version
ID:	72137   Click image for larger version
2015 Coachman Chaparral 360IBL
2012 6.7L Ford F350 SRW
53 nights camped in 2017.
farmncamp is offline   Reply With Quote
Old 03-25-2015, 12:02 AM   #2
did you figure out the jumper thing for the delay? i even called them and still could not understand where the jumper was to adjust the kick back on time cycle and said hell with it and just installed it. Yes the 50 amp wires suck trying to get the wires in the terminals. Looks good nice clean install
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 03-25-2015, 12:26 AM   #3
farmncamp's Avatar
I left it as is (15 second delay). My coach has new enough AC / Thermostat that will delay starting the ac compressor in the event of a power failure. Older coaches sometimes don't, which is why they have the jumper.
Old 03-25-2015, 07:51 AM   #4
Mr. Dan's Avatar
Let's see if this works from Sept. 19. 2014. CLICK on each attachment name.
Originally Posted by Mr. Dan View Post
Jumper ON
Attachment 63066
Jumper OFF
Attachment 63067
Text with pics: 'you can find it next to the receptacle for the data cable. It is a small black plastic square (ľ x ľ inch) mounted vertically. It is next to a small yellow capacitor and exposes two metal pins'
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 03-25-2015, 12:15 PM   #5
Nice install. Thanks for the pictures!
ottawapaul is offline   Reply With Quote
Old 03-25-2015, 09:22 PM   #6
scootingranny's Avatar
Showed this thread to DH. Definitely something we will do on our 360 IBL but will have to wait until we get new tires and some necessities for inside. He just put it on his TO DO list. This weekend he's putting on the JT strongarms that you had previously recommended.
scootingranny is offline   Reply With Quote
Old 03-25-2015, 09:40 PM   #7
gashog's Avatar
Buying and Installing one of these Progressive EMS HW50C is at the top of my to do list. I do a lot of internet shopping in search for the best price. So far this is the best that I've found $315.85 free shipping at Progressive Industries EMS-HW50C Hardwire RV Surge Protector 50 Amp
Did you find a better price, if I may ask?
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 03-25-2015, 09:42 PM   #8
farmncamp's Avatar
Nope that's the best I've seen. Buy it!
Old 03-25-2015, 09:50 PM   #9
Mr. Dan's Avatar
I got mine here: RV Safety Accessories Inc $305.00
Old 03-25-2015, 09:54 PM   #10
gashog's Avatar
Even better THANK YOU. I hope this goes like a auction in reverse and the price keeps dropping, but $305.00 likely won't be beat...
50 amp
