Old 03-20-2015, 07:37 AM   #1
Progressive Industries EMS-HW50C
Just got my Georgetown 337 back from dealer. The next day my ems arrived. My question is where should I put the display unit? I've already planned to put a plug in the power bay so I will no longer have to drag 30 ft of 50amp cord in and out of the access hole.
2011 Georgetown 337 2011 Chevy Impala
pakkdad is offline   Reply With Quote
Old 03-20-2015, 07:42 AM   #2
TURBS's Avatar
Ultimately put it where it works best for you.
Mine is right inside the main door so I can pop open the door and look at it.
I also don't have a mh so so this may vary from where you can install it.
I don't follow what your doing with your power cord tho.
Old 03-20-2015, 07:53 AM   #3
Thanks Turns, I'm changing from a hard wire cord to one with 2 ends. My thought is it will be a lot easier to pull the whole thing out and feed 2 feet up into the compartment. Than pull 30 ft in and out a 4in hole.
Old 03-20-2015, 08:01 AM   #4
geotex1's Avatar
Sure is! I've done this a lot over the years for friends and friend of theirs! If you have room for it, I have installed many times a quality industrial hose reel and wound the cord on that. Last year, I even went a step further with a couple in their mid-80s (who have been full-timing for 33 years!!!) and fitting their reel with a reversible electric motor to help them bring that beast in. Why the RV industry does not use higher number, finer stranded wire for their power umbilical to increase flexibility...
I vote a dual display with a MH! One at the bay where everything is, and one inside to monitor the state of things.
geotex1 is offline   Reply With Quote
Old 03-21-2015, 04:15 AM   #5
CCRVOC
Ramblin Recks's Avatar
X2- I have mine mounted just inside the door, which I like to monitor throughout the day, but it would be nice to have one in the bay to be seen when I first connect power.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 03-21-2015, 09:53 AM   #6
TURBS's Avatar
Well it has a delay , if you run fast enough. ..........
Old 03-21-2015, 10:00 AM   #7
Mr. Dan's Avatar
... about 16-17 seconds for mine.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 03-21-2015, 10:06 AM   #8
TURBS's Avatar
Hardwired has two delays, I cannot remember them but may 15 seconds and 136 ?
Old 03-21-2015, 01:59 PM   #9
Thanks, yes 15 and 136. To do with AC units they say. Any easy ways to run the data cable?
