Old 10-24-2015, 10:38 AM   #1
pfeather1's Avatar
Propane hookup
Got tired of hitting my head when I had to crawl under the trailer to hook up my stove for outdoor kitchen- so with $25 of pipe I moved quick connect to inside of outdoor kitchen Click image for larger version
Name:	ImageUploadedByForest River Forums1445701063.982900.jpg
pfeather1 is offline   Reply With Quote
Old 10-26-2015, 09:51 AM   #2
good mod, ....... also in the photo I think I see awning posts,...... to me, part of the fun of owning a trailer is thinking of ways it can be improved
fella10 is online now   Reply With Quote
Old 10-26-2015, 09:55 AM   #3
(Dry Huunday)
DreiHunde's Avatar
Nicely done!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is online now   Reply With Quote
Old 10-26-2015, 10:20 AM   #4
Citrus County, Fl.
GL1800Rider's Avatar
Exclamation
Propane police here.....35 years in the fire service so I just had to note this scares the hell out of me:
Propane is heavier than air. You are putting this in an enclosed compartment with 110v receptacles in close proximity. Air + Fuel + Ignition Source in the right mixture = Boom
Just be careful, you may want to mount a second propane alarm as a mod.
http://www.amazon.com/MTI-20-441-WT-...=propane+alarm
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 10-26-2015, 10:22 AM   #5
B and B's Avatar
X2 that is why they removed the quick connect hose on the Rockwood 8289. It is inside the trailer itself. Did you use white teflon tape for the joints?
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 10-26-2015, 01:57 PM   #6
pfeather1's Avatar
No I used the yellow for gas tape do you think I should try and move it to the outside? Dealer thought it would be ok because some tent trailers have them inside - thanks for your input
Old 10-26-2015, 04:33 PM   #7
pfeather1's Avatar
Thought about that - that's why I put a shutoff in the line that will only be open when outdoor kitchen door is open. Propane leak detector will be reinstalled in spring and other outlets will have blocked plugs. Any other suggestions?
Old 10-28-2015, 02:43 AM   #8
johngoat2002's Avatar
At work, some of our confined spaces have ventilation fans that remove possible gas buildup in low areas. If you were to decide to do something like this, it wouldn't need to be a large fan for the area you have it in. 3" or 4" fan.... Maybe do a mod for a door switch with the door closed and the batteries on.
2005 Flagstaff FS26
2006 GMC Sierra Denali 6.0L
HP Tuner
johngoat2002 is offline   Reply With Quote
Old 10-28-2015, 06:24 AM   #9
Witch Doctor's Avatar
The only thing that I would think about is moving your shut off valve outside, Then if it leaked it would leak to outside. Other then that you would only have the valve on when the kitchen door is open. As you said you will have block offs on the electrical outlet.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 10-30-2015, 04:27 PM   #10
pfeather1's Avatar
Done and done. Shutoff valve now under trailer and electric receptacles plugged. Tested all joints for leaks will buy/mount a propane detector in the spring
propane
