Old 06-30-2015, 08:07 PM   #1
Propane quick connect
I want to plumb a propane quick connect under my 2008 Sierra Sport. Are there any options other than black pipe. Maybe like a flexible line?
Overachiever is offline   Reply With Quote
Old 06-30-2015, 08:15 PM   #2
mshell56118's Avatar
I believe you could use copper line
Sent from my iPad using Tapatalk
mshell56118 is offline   Reply With Quote
Old 07-01-2015, 07:13 PM   #3
D LBRS's Avatar
I used brass fittings to 'T' off the gas system just past the auto-changeover valve. From the 'T', I used one of those 10 foot gas grill extension hoses (rubber) from Home Depot to run over to the door side of the 5er through the same conduit that houses the hose that joins the two tanks. Then, I used a brass coupler to add another 10 foot hose. At the end of this hose is a gas appropriate ball valve followed by a quick-disconnect fitting. The mate to the QD is installed on my Weber Q grill. I roll the hose up and use a Velcro strap to store at the hand-hold of the propane tank. When I get ready to hook up the grill I open the propane access door and drop the hose out the bottom. I felt comfortable using rubber hoses since I essentially mimicked what was already there to join the tanks.
D LBRS is offline   Reply With Quote
Old 07-01-2015, 07:20 PM   #4
D LBRS's Avatar
I should also note that all the propane lines in my 5er are rubber. There is a main line that runs down the frame and branches off to each appliance.
I was able to use the pre-made hoses from Home Depot but you could also get custom hoses made at a local hose/rubber shop. Just make sure that you proper fittings and check everything for leaks with soapy water.
propane
