Forest River Forums
Sunline User Photos
Old 05-26-2009, 11:00 AM   #1
froale's Avatar
Pump Storage Upgrades
I got really tired of the vibration & noise my water pump made so I got busy and revamped my pump area. I started with installing flexible hoses so the vibrations don't carry down the rest of my plumbing lines. Then added an accumulator tank (pressure tank) to make the flow more even instead of cylcing pressure. Rubber pads (old truck bed mat material) under pump and first connection after accumulator tank. R-4 Styrofam insulation on all sides of the compartment for sound and heat. Clamped piping before and after flex hoses with rubberized clamps for vibrations. Installed a tee valve so I can pump in RV antifreeze easily for winterizing. Rerouted and clamped the LP sensor wiring. Strainer filter before pump to get any chunks or sand that might get in the diaphragm.
I have also added the pipe foam insulation around most of the rigid piping since I took the photos.
With all of this done I have to really listen for my pump it's so quiet now! Hopefully the insulation of the waterlines and compartment will help reduce chances of freeze up as well for fall hunting. I did leave small gaps in the insulation so heat from inside the camper will still get into the compartment.
The pump is now purring like a kitten, producing even flowing water, and hopefully protected better from cold. Forest River sould do this stock it only cost around $60 for the entire upgrade.
Let me know if anyone sees anything blatantly wrong with the setup.
Thanks for looking,
Jeff
2003 Ford F150 SuperCrew-5.4 Triton
2003 Wildwood 23BHLE
froale is offline   Reply With Quote
Old 05-26-2009, 11:27 AM   #2
Moderator
mtnguy's Avatar
I like it !!!! I just might incorporate a few your ideas into my setup.....that is of course you don't have a patent on things.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is online now   Reply With Quote
Old 05-26-2009, 04:54 PM   #3
powerboatr's Avatar
great mod
and the spare parts box is a BIG A PLUS
thanks for the write up
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 10-22-2009, 10:55 PM   #4
Send a message via AIM to pjeffreysr1
I need to add a "winterizing" system to our new Wldwood 26BHXL. Where did you get the "T" valve?
pjeffreysr1 is offline   Reply With Quote
Old 10-23-2009, 07:19 AM   #5
volunteer moderator
Only one question--- do you make house calls?
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
Old 10-27-2009, 10:01 AM   #6
froale's Avatar
Sorry I haven't replied to the posts sooner, busy on the next upgrades.
I don't have a patent, so go for it! It's been one of my better upgrades.
You have to have spare parts, to insure that they never fail. As we all know the parts that fail are the ones you don't have replacements for.
The "T" was already installed, but you can get them at about any hardware store.
As far as house calls go, getting from Montana to anywhere is a roadtrip! It takes a good part of the day to get out of state!
I'll be posting some more upgrades soon on winterproofing with tank heaters, and solar. Got to get through hunting season and see how it all goes!
Old 10-27-2009, 05:59 PM   #7
i was wondering where you got the accumulator tank?
firedude01 is offline   Reply With Quote
Old 11-03-2009, 07:35 AM   #8
miatared's Avatar
Accumlator tank ?
I just got one off eBay for $38. It is a ShurFlo model #181-201 - if you do a search on eBay or Google you will see many are selling it. I am sure you can get one from your local RV shop. It does make a big difference - I installed one in my MH years ago and it was so much better. I will install this one in my new Shamrock 19.
Denis
miatared is offline   Reply With Quote
» Online Users: 543
89 members and 454 guests
12vdzl, 4bnabird, 4runner freak, 8261ss, abjb, backpacker3, Barney1, Bearcat55, bfisher82, bikendan, bob7794, bouldercamper, brania, buzzmonster, campfun, CampinQueen, Canuck_Doug, carsonizik3, chiro, ClampNfish, cmptrkd, cousin01, Cowracer, cstover, dashonthedash, daw592, depo, djorgensen3, dlmurray51, DonCath25ds, DonG, donh, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, JJFerg, JLcampgirl, Joseph5410, kgmat, KKapa, Lonewolfcry, Mad4sax, mcdiver, mike1329, Mkayers, Mpwelch50, mtnguy, NeilM108, onetonford, Pa-cj5, Pinesman, Poppy Bill, PrairieBoy, punkaccountant, rbrandon, rglickman, RichN, Riva, Roamin Ovum, rschroe, Rugged Brown, Russ, Scriggs1, seatosea, Sparkbark, SpringerPop, tfennell81, TheSasks, Titleguy, Tom993, tonybab, troyt, UPGRADER, VTX Al, wbdvt, wfmdfm, Whiskeyjack, Whiteknight, whj77372
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
