Old 10-16-2014, 08:48 AM   #1
Road-King's Avatar
PVC Dish Tailgater Stand
Thought I would post this for anyone like me who doesn't like their ($300) Tailgater sitting on the ground.
ID:	64831Click image for larger version
Parts needed;
20' Schedule 40 1" PVC
8 X 90s
8 X Tees
All parts are 1" Schedule 40 PVC.
The top support square uses;
Cut 4 X 9 1/2"
Cut 4 X 1 1/2"
4 X Tees
4 X 90s
The bottom support square uses;
Cut 4 X 17 1/2"
Cut 4 X 1 1/2"
4 X Tees
4 X 90s
For the support legs I cut 4 X 25". The support legs are at an angle because the top square is smaller than the bottom. If you put the Tees in the middle of each cross piece, both top and bottom, I don't think you would have the angle's. But I was okay with it. I glued the top square and the bottom but left the support legs UN-glued so I could break it down for storage and transport. I plan on using 2 bungee cords and a 5 gal bucket, full of water as an anchor.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 10-16-2014, 10:06 AM   #2
I put mine on a 2' by 2' piece of 3/4'' plywood. Screwed in a couple hooks and bungee it on tight. The plywood base is heavy enough to hold it down.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 10-16-2014, 10:14 AM   #3
Made 2 different mounts for mine, one for the pinbox and one for 3 different locations on the ladder. I also carry a tripod I made for the old Dish antenna that can be used.
ID:	64846   Click image for larger version
ID:	64847   Click image for larger version
ID:	64848   Click image for larger version
Old 10-16-2014, 02:46 PM   #4
Road-King's Avatar
Plan B
Plan B
The twist did start to bother me, so I did a mod on the bottom square. I used;
Cut 8 1/2" pipe
Cut 16 1/4" pipe
same 90s and Tees.
Now it's straight and has a little larger base square.
Russ & Kim
2014 Alpine 3600RS
Old 10-16-2014, 06:02 PM   #5
Paradise has arrived!
Paradise115's Avatar
I'm thinking of getting the tailgater next season. Thanks for the ideas!
Southwestern Pennsylvania
Paradise115 is offline   Reply With Quote
Old 10-16-2014, 06:57 PM   #6
Campin Cajun's Avatar
Good work Road King!!
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-16-2014, 07:09 PM   #7
GASPEDDLER's Avatar
Following
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 10-16-2014, 07:28 PM   #8
nice work
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 10-16-2014, 08:39 PM   #9
ColoradoRick's Avatar
Wow, you guys are wicked smart!!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 11-29-2014, 11:58 PM   #10
Nice work, and engineering
jimmyt11664 is offline   Reply With Quote
tailgater, television
