Old 04-14-2016, 11:01 AM   #11
Quad steps
I have looked into this for my 2015 Silverback 29re. Current steps appear to be welded to frame as well as bolted to the floor.
WyomingJack
2015 CC Silverback 29 RE
2014 GMC 2500 HD
WyomingJack is offline   Reply With Quote
Old 04-14-2016, 11:54 AM   #12
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
I can't say for sure on your 2015 model but our 2014 Silverback had a mounting bracket that is "welded to the frame and bolted to the floor" and then the Flexco step assembly then bolted with 4 bolts(2 each side) to that mounting bracket along with 2 self-tapping screws(1 each side)....hopefully you can see the nuts for the bolts and the screwhead in the pic ....I removed the 4 bolts and the self-tapping screws and the step assembly simply dropped right out away from the mounting bracket.....I did have to trim about 1.25 inches from the bottom of the bracket for the quad steps to fit back in the holes.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 04-14-2016, 12:28 PM   #13
Quad steps
Thanks, I will give it another " closer" look.
WyomingJack
2014 GMC 2500 HD
Old 04-16-2016, 08:06 PM   #14
keith52's Avatar
Originally Posted by tkmi View Post
Can you fold the steeps up with covers on them?
I have the Flexco quad steps on our Cedar Creek. Purchased the Presto Fit step covers and they have 4 springs each to attach the cover to the step. Well, they would not work as designed. The quad steps seem like they almost have to be metal to metal when they are folded up. I'm still trying to figure out some way of covering the metal with some type of cover.
keith52 is offline   Reply With Quote
Old 04-20-2016, 03:20 PM   #15
If you're going to consider a step-upgrade, look at the Torklift Glowstep Revolution steps. I had 2 sets installed on my rig and couldn't be happier with them.
RV Step Fail - RV Step Fail Blog
X2. Best upgrade on our fiver to date. Had an elderly disabled lady try ours out last weekend while camping and she was amazed how much easier they were to climb.
Sierra360PDEK is offline   Reply With Quote
