Old 09-09-2017, 12:18 PM   #1
Queen Rv mattress to Residential pillow top
We changed out our Rv queen mattress to a residential pillow top mattress. I could carry the rv queen with one hand it was so light. It took the wife and I to carry the residential queen in. Granted the residential was about 3-4 inches longer but it still gave us lots of room at the foot of the bed. The problem we did have was the shocks under the bed would no longer hold the mattress up while we pack things under the bed. After some research I found out the shock is a 20" 80lbs shock. So I looked around and found a direct replacement that was 150lbs. It worked like a charm and it was only 30 for both shocks. Now it holds up the residential pillow top and lets us get things out or put things under the bed.
Lenny
2012 Ram 2500 4X4 Short bed Diesel
2015 Wildcat 275 CK
lennyd96 is offline   Reply With Quote
Old 09-09-2017, 08:48 PM   #2
We have a Trump mattress, it sleeps better than our mattress at home
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 09-11-2017, 11:18 AM   #3
I also upgraded to the "full" queen mattress. But I used a sleep number so it is light enough that the shocks still worked.
Is your mattress stiff enough that it doesn't hang down where it is not supported?
I added 6" of plywood under mine to support the full length
(once the hatch is closed then the mattress barely sticks past the wood)
mkosu04 is offline   Reply With Quote
Old 09-11-2017, 08:05 PM   #4
Lenny;
Can you tell me where you got the heavier duty shock. We are using the stock mattress with a heavy down featherbed, which is great for sleeping, but just ripped out the hinges and pulled the shocks out. Thanks.
planecrashlaw is offline   Reply With Quote
Old 09-11-2017, 08:57 PM   #5
King of the Road
Originally Posted by planecrashlaw View Post
Lenny;
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
These are 240lb hold (2X120) they come in different strenghts.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
Old 09-11-2017, 09:01 PM   #6
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
Our Columbus several years ago came with a Serta Trump Series. After our first camping trip on that we went to the mattress store and bought one for home.
Robert & Estha Shiflet
'17 Cardinal 3456RL - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016: 587 ~ Nights Camping 2017: 99 So Far
rjshiflet is offline   Reply With Quote
Old 09-11-2017, 09:06 PM   #7
King of the Road
You're not supposed to say "Trump" on this site. To political, forbidden. Read the TOS.
2016 Crusader Lite
Single slide
Old 09-12-2017, 07:19 AM   #8
I bought mine at newegg. I deal with them for computer parts and when it pulled up for the shocks I pulled the trigger. They come in a pair and for 30.00.
https://www.newegg.com/Product/Produ...9SIAAR73ZW4602
2015 Wildcat 275 CK
Old 09-12-2017, 08:11 AM   #9
Thanks. That is what I went with. Funny, the difference between the 100# and the 120# on Amazon is 10 cents, but an 80# is $10 more.
One last quick question. Are the mounting brackets compatible, i.e. I only need to replace the struts?
Old 09-12-2017, 08:50 AM   #10
King of the Road
That's all I did, just get the same length. I think the 20" worked for me. They will not compress easily by hand, just open the bed, remove the old, install the new without compression and close the bed. Easy Peasy..
2016 Crusader Lite
Single slide
