Forest River Forums
Sunline User Photos
Old 01-08-2012, 04:57 PM   #1
Question: Adding an electrical outlet
My new 2012 Palomino Ultra-Lite T245 arrived this week. Dealer is storing for me until spring. Spent Friday "bonding" with the trailer. It is perfect in every way, accept, there is no electrical outlet near the dining table. The nearest outlet is on the overhead where the tv is mounted above the table. Can the dealer add an outlet below the window (the heater duct work runs alongside the benches below the window) at a reasonable cost? Or would I be better off running an extension cord under the overhead and down the corner?
djellis is offline   Reply With Quote
Old 01-08-2012, 06:39 PM   #2
Mountainmanbob's Avatar
electricians are looking for small jobs
the dealer should be the one
that can do just about anyTHING
for the right price
extension cord is not a terrible idea
but
if you can not or wish not
to do it yourself
many electricians on craigslist
and will charge a fair price
MM
Mountainmanbob is offline   Reply With Quote
Old 01-08-2012, 11:20 PM   #3
Moderator
Depends on a lot. Is there an available space to add a breaker in the electrical panel? Is there a path that the wire can be run to put an outlet where where you want it? Without looking at your floor plan, do you want the outlet in a slide portion of the trailer? It can be done, but costly.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 01-09-2012, 11:28 AM   #4
Dave_Monica's Avatar
I'm surprised that there's not an outlet on the inside face of one of the dinette benches...there's usually one. Check in the storage area under the dinette benches to see if any 120V cable passes through them. If so, it would be easy to add an outlet where I mentioned.
Due to the construction of the fiberglass walls, you'll seldom (if ever) see a electrical outlet on an outside wall.
Dave
2008 F250 CC SB 6.8L V10
2010 Rockwood 8280WS
Nights camped in 2010 - 58, 2011 - 43, 2012 - 20
Old 01-09-2012, 01:18 PM   #5
Took me a year to realize there was an outlet on the face of the dinette bench near the wall. LOL.
jim44646 is offline   Reply With Quote
Old 01-09-2012, 02:33 PM   #6
Outlet Mod
I also have an outlet in the bench of my dinette. But, camping over New Years we were using an electric 1800 watt heater. Found out quickly that if you use the heater AND use another major electrical appliance like a coffee pot or hair dryer, you trip a breaker in the trailer box. So, I have decided to mod only that outlet by disconnecting it from the internal trailer panel and installing an external box that I can connect, using a heavyduty extention cord back to the parks 20 amp circuit breaker. I can then use that outlet for the heater and also use other appliances at the same time without tripping the trailer circuit breakers on the inside box. The dinette is on a slideout so I have easy access. All of this is to say that if you are thinking of adding an outlet, this might be a much easier solution, depending on where you want the outlet.
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe and 1 spoiled Chihuahua
1Texan is offline   Reply With Quote
Old 01-09-2012, 02:48 PM   #7
volunteer moderator
HI Donna!
Welcome to FRF!!
Like others have mentioned, check carefully way back in the corner
under your dinette table.
I bet there's an outlet hiding back there.
OTOH, my electrical panel has extra slots.
It was pretty easy to add a circuit breaker (they just plug in) and run a short
wire to the toe kick area right next to the panel.
I added a box and outlet there that's on it's own separate circuit.
This allows us to perk coffee via the outlet next to the sink and keep
a space heater on via the outlet I added and not blow any circuit breakers!
Look again and let us know if you for sure don't have an outlet under the table.
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
Old 01-09-2012, 03:41 PM   #8
RubenZ's Avatar
Our Palomino puma 23FB has an outlet right center under the dinette. Just double check.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
» Online Users: 542
89 members and 453 guests
12vdzl, 4bnabird, 4runner freak, 8261ss, abjb, backpacker3, Barney1, Bearcat55, bfisher82, bikendan, bob7794, bouldercamper, brania, buzzmonster, campfun, CampinQueen, Canuck_Doug, carsonizik3, chiro, ClampNfish, cmptrkd, cousin01, Cowracer, cstover, dashonthedash, daw592, depo, djorgensen3, dlmurray51, DonCath25ds, DonG, donh, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, JJFerg, JLcampgirl, Joseph5410, kgmat, KKapa, Lonewolfcry, Mad4sax, mcdiver, mike1329, Mkayers, Mpwelch50, mtnguy, NeilM108, onetonford, Pa-cj5, Pinesman, Poppy Bill, PrairieBoy, punkaccountant, rbrandon, rglickman, RichN, Riva, Roamin Ovum, rschroe, Rugged Brown, Russ, Scriggs1, seatosea, Sparkbark, SpringerPop, tfennell81, TheSasks, Titleguy, Tom993, tonybab, troyt, UPGRADER, VTX Al, wbdvt, wfmdfm, Whiskeyjack, Whiteknight, whj77372
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
